Would like to understand if i'm interpreting how to use handlers and matchers correctly
I have a site block that looks like this:
example.com:443 {
        @accept client_ip 10.10.0.0/16
        @denied not client_ip 192.168.54.0/24
        handle @accept {
                reverse_proxy 192.168.54.7:80
        handle @denied {
                abort
I want to make sure I understood the documentation correctly. From what I’ve read, I understand this site block to mean:
  1. Any requests from the 10.10.0.0/16 network should be accepted and reverse_proxied to 192.168.54.7:80.
  2. Any requests NOT from the 192.168.54.0/24 network should abort (unless already accepted by the @accept matcher in step #1).
  3. All other requests not rejected by #2 or already accepted by #1 should now be accepted.
Is this the correct interpretation? Basically: accept requests from 10.10.0.0/16 and 192.168.54.0/24, and abort all others? Is there an easier way to do this? I was thinking this would do the same thing and would be simpler:
example.com:443 {
        @accept client_ip 10.10.0.0/16 192.168.54.0/24
        handle @accept {
                abort
no error messages.  both seem to work fine i believe.....
3. Caddy version: v2.9.1
using docker.
ubuntu 24.04
docker compose up
    image: caddy:latest
      - "443:443/udp"
      - ./site:/srv
      - caddy_data:/data
      - caddy_config:/config
      - reverse_proxy
  caddy_data:
  caddy_config:
  reverse_proxy:
    external: true
example.com:443 {
        handle @accept {
        handle @denied {
                abort
As you noticed, handle directives are mutually exclusive, meaning if one handle of the set is executed, the others are not. This means the last handle block in your very first config is never executed. The simpler config that you developed works the same and is slightly more efficient.
