V2.2.1
Debian 10 normal install via apt install caddy
systemctl start caddy.service
paste full file contents here
myblog.mydomain.com {
root * /var/www/html/blog.com
php_fastcgi unix//run/php/php7.3-fpm.sock
output file /var/log/caddy/stephaniebreton.com.log
format console
I can access myblog.mydomain.com but then permalinks are not working and access to wp-admin is not working. I tried to add in the Caddyfile: try_files {path} /index.php?{query}&p={path} but it also does not work. Basically whenever there is myblog.mydomain.com/[path] it does not work as it does not add the “index.php” in the uri, finally anything like myblog.mydomain.com/wp-admin/anyfile.php will not work such as myblog.mydomain.com/wp-admin/update-core.php
I tried try_files {path} /index.php?{query}&p={path} but when i query a page it shows 404 error and sometimes after refreshing it works sometimes not.
I have searched for the past two days but all the config i see for wordpress are minimal and does not work for me
Thanks for your help as i am currently with Nginx but would like to use Caddy if i can get this wordpress to work.
