Wordpress not working properly behind Reverse Proxy
When having deployed Wordpress on a VM in a secure (private) environment behind a Caddy RP, Several things are not loaded properly
Mixed Content: The page at 'https://wp1.biteach.de/wordpress/wp-admin/setup-config.php' was loaded over HTTPS, but requested an insecure script 'http://wp1.biteach.de/wordpress/wp-includes/js/jquery/jquery.min.js?ver=3.7.1'. This request has been blocked; the content must be served over HTTPS.
v2.7.6
Debian 12.4 on a Linux Container (LXC)
The system has two interfaces.
One is a public interface with a public IP
THe other is a privat 10.0.0.0 address pointing towards the webserver where wordpress is running on a ISPConfig machine. (Note: The ISPConfig is NOT the problem, I have a similar construct running on a PUBLIC vServer with no problems at all, and both systems are setup identically).
n/a
# domain name.
        root * /usr/share/caddy
        # php_fastcgi localhost:9000
wpdev.test.magiserv.de {
        reverse_proxy 10.172.2.113:8080
wp1.biteach.de {
        reverse_proxy http://10.172.2.113
wp2.biteach.de {
wp3.biteach.de {
wp4.biteach.de {
wp5.biteach.de {
wp6.biteach.de {
wp7.biteach.de {
wp8.biteach.de {
proobjekt.test.magiserv.de {
                output file /var/log/caddy/proobjekt.test.magiserv.de.log
                level INFO
Remove this from your config. You’re meant to replace this with your own config, not leave it in.
Sounds like WordPress isn’t reading the X-Forwarded-Proto header to know to produce paths with https:// instead of http://.
You’ll need to research how to fix that with WordPress. Not a Caddy issue.
