1. Caddy version: v2.4.6
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy
Ubuntu 20.04 LTS
NA
on_demand_tls {
ask https://microweb.app
interval 2m
burst 5
https:// {
on_demand
root * /home/forge/microweb
php_fastcgi unix//run/php/php8.0-fpm.sock
thinkfinserv.com {
redir https://www.thinkfinserv.com{uri}
I’m running the above configuration to host a WordPress Multisite; with subdomain configuration. I’ve had permalinks set-up to /%post% for a while which gave me clean urls like artha.microweb.com/post-name.
Today, I logged in to create a new site and found out that wordpress’s permalink structure began showing index.php in the permalink settings. For example: https://artha.microweb.app/index.php/sample-post/
I did not change any settings on my own on the Caddy front or even on WordPress settings that’d trigger this change. I’ve only upgraded WordPress to its latest version; and I’ve no clue why’d WordPress begin showing index.php in URLs.
When I create a new post, it automatically tries to include index.php in the URL, HOWEVER, the clean url works. That is
→ When I create the post, the url is shown as /index.php/good-world/ which throws 404
→ BUT if I visit /good-world/ → the page loads fine.
I’m super confused by this behavior. Can’t figure out why’d this happen.
I don’t know if this is a result of upgrading wordpress or something else. My best guess is that .htaccess has nothing to do with this, but I’ll post the recommended .htaccess configuration by wordpress in my network admin below -
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
# add a trailing slash to /wp-admin
RewriteRule ^wp-admin$ wp-admin/ [R=301,L]
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^ - [L]
RewriteRule ^(wp-(content|admin|includes).*) $1 [L]
RewriteRule ^(.*\.php)$ $1 [L]
RewriteRule . index.php [L]
I’ve already tried verifying my Caddyfile configuration; which seems to be unaltered. Let me know if this looks like a WP issue and not a Caddyfile issue.
