v2.3.0
Ubuntu 20.04
paste command here
paste full file contents here
# Caddyfile
# Global options
# TLS Options
email
# Server Options
servers {
protocol {
experimental_http3
strict_sni_host
# Inheritated config
(common) {
encode zstd gzip
php_fastcgi unix//run/php/php-fpm.sock
(rewriteRule) {
# URL
testurl123.com {
root * /var/www/html
import common
import rewriteRule
@disallowed {
path /xmlrpc.php
path *.sql
path /wp-content/uploads/*.php
rewrite @disallowed '/index.php'
# Enable HTTP Strict Transport Security (HSTS) to force clients to always
# connect via HTTPS (do not use if only testing)
# Prevent some browsers from MIME-sniffing a response away from the declared Content-Type
# Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "DENY"
# Be extremely restrictive.
# https://developers.google.com/web/fundamentals/security/csp/
Content-Security-Policy "default-src 'none'; block-all-mixed-content"
Cache-Control "no-cache, no-store, must-revalidate"
# log
# folder needs to be created --> mkdir caddy
# owner needs to be set --> chown -R caddy /var/log/caddy
# restart caddy --> systemctl restart caddy
output file /var/log/caddyaccess.log {
roll_size 20mb
format console
Has anyone already adapted the htaccess rewrite rules for wordpress multisite in caddy syntax?
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
# add a trailing slash to /wp-admin
RewriteRule ^wp-admin$ wp-admin/ [R=301,L]
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^ - [L]
RewriteRule ^(wp-(content|admin|includes).*) $1 [L]
RewriteRule ^(.*\.php)$ $1 [L]
RewriteRule . index.php [L]
“Step 4: Enabling the Network”
Thank you!
