Caddyfile
Debian 10 via systemd, installed using official Debian repo
PHP 7.4.11 (cli) (built: Oct 18 2020 19:44:48) ( NTS )
sudo systemctl start caddy
https://cloudfree.shop {
root * /var/www/html/cloudfree.shop
respond /uploads/*.php 404
X-Frame-Options DENY
Wordpress’ Jetpack plugin is unable to fully connect to Jetpack servers
I have reached out to Jetpack support. Here are the details they have given me.
26 Oct 2020
Specificially, I’m seeing this error in the XML-RPC requests for your site: The required “url” parameter is malformed. With response code:
invalid_signature. It’s possible that something on the server isn’t set up quite right and is causing this response.
3 Nov 2020
Our developers have provided an update on the matter.
After some debugging here’s what they have found out that for some reason, it appears that your server is not informing the port being used in the PHP variable$_SERVER['SERVER_PORT'].
On our side, we don’t handle this very well, and the port ends up being considered as0here:
We then append
:0to the URL and, later on, this URL is considered malformed and thus the XML-RPC error we get.
To solve the immediate situation, we have to understand why your server is not properly returning the port number to PHP.
From this PHP documentation:
Note: Under the Apache 2, you must set UseCanonicalName = On, as well as UseCanonicalPhysicalPort = On in order to get the physical (real) port, otherwise, this value can be spoofed and it may or may not return the physical port value. It is not safe to rely on this value in security-dependent contexts.
So it may be that your Apache configuration is not returning the physical port value.
https://www.php.net/manual/en/reserved.variables.server.php
TL;DR: How do I set the SERVER_PORT PHP variable in Caddy 2?
