ikifar
(Matheson Steplock)
December 31, 2018, 7:34pm
1
Hi, I am trying to setup Wordpress on caddy server but it does not seem to be fully working. wp-admin works but the main page does not:
https://www.glennsteplock.ca {
proxy / 192.168.0.17:333 {
gzip
dns cloudflare
rewrite {
if {path} not_match ^\/wp-admin
to {path} {path}/ /index.php?_url={uri}
log stdout
Any help would be appreciated
Hi @ikifar ,
It looks like that guide is for proxying to a WordPress container, not serving WordPress directly.
Did you follow a different guide?
When the main page does not work, can you elaborate on what happens? Do you get an error, or some other unexpected result?
ikifar
(Matheson Steplock)
January 1, 2019, 6:50pm
3
the home page looks like plain html,
@Whitestrake how would you setup wordpress I am running caddy in docker with an image i created to have the cloudflare plugin
docker build --build-arg \
plugins=cloudflare,git \
github.com/abiosoft/caddy-docker.git
Hmm, you don’t have PHP configured in that setup, so any PHP files will just be handled as raw text / HTML. That’s probably breaking your setup.
If you use the WordPress container instead, you don’t need to run and configure PHP in Caddy, you just proxy to it.
As for how I’d set up WordPress, here’s what I use for Docker:
image: abiosoft/caddy:latest
command: ["-log", "stdout", "-agree",
"-email", "letsencrypt@whitestrake.net",
"-conf", "'/etc/caddyfiles/*.caddy'"]
- 443:443
- ./caddyfiles:/etc/caddyfiles
- ./certificates:/root/.caddy
- ./sites:/srv
wordpress:
image: wordpress:php7.0
depends_on:
- database
WORDPRESS_DB_PASSWORD: [snip]
WORDPRESS_DB_HOST: database
- ./wordpress:/var/www/html
database:
image: mariadb:latest
MYSQL_ROOT_PASSWORD: [snip]
- ./database:/var/lib/mysql
And this is the part of my Caddyfile that configures my WordPress site:
example.com {
redir https://www.example.com{uri}
www.example.com {
proxy / wordpress {
ikifar
(Matheson Steplock)
January 1, 2019, 7:20pm
5
@Whitestrake How can I setup php for my current setup
Really can’t go past this guide hosted on the Caddyserver repo.
There’s even a great Caddyfile example there.
