{Will pay for help!} Websockets Reverse Proxy
v2.1
Windows Server 2016
:43001 {
reverse_proxy {
to 10.0.0.102:4000
header_up Host {http.reverse_proxy.upstream.host}
header_up X-Real-IP {http.request.remote_host}
header_up X-Forwarded-For {http.request.remote_host}
header_up X-Forwarded-Proto {http.request.scheme}
@websockets {
header Connection * Upgrade *
header Upgrade websocket
I want to send Websocket requests (wss) coming in on port 43001 to other socket servers. Im not getting a proper socket handshake on the socket server side.
2020/07/07 17:54:46.419 ←[31mERROR←[0m http.handlers.reverse_
with incomplete response {“error”: “context canceled”}
Socket Server is getting the connection but fails handshake, therefore closes connection.
Tried so many examples and read docs, I cant figure this out.
Doesnt seems like Im needing it to do much, just a simple load balancer..
Current CaddyFile is:
:43001 {
level DEBUG
output file caddy_test.log {
roll_size 10MiB
roll_keep 10
roll_keep_for 336h
handle_path /* {
reverse_proxy 10.0.0.102:4000
Client is disconnecting because of failed handshake.. I dont know what Im doing wrong…
For paid help please see this page:
At a glance it seems the issue is due to TLS not being enabled, or the upstream expecting TLS and the proxy request not having TLS.
For the former, try using a domain name and port 443 to let Caddy automatically set up TLS.
For the later, try enabling the tls http transport option of the reverse_proxy directive.
Please use ``` on the lines before and after your config to use code formatting in your forum posts, it will preserve whitespace and make it much more readable. It’s hard to follow as-is.
