derrickr
(derrickr)
April 22, 2022, 4:44pm
1
I’ve looked, but can’t specifically find anyone saying that Caddy won’t run on an older RasperryPi Zero W v1.1
i.e. 32bit instead of 64bit OS
I’m guessing it’s as simple as that, but just wanted to make sure.
Latest
That’s the problem, it’s not running
Raspberry Pi Os Lite - 32 bit verion
sudo apt install caddy
N/A
root * /usr/share/caddy
Caddy won’t start
user@pizero1w:~ $ systemctl status caddy.service
● caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Fri 2022-04-22 16:54:09 BST; 1min 12s ago
Main PID: 1740 (code=killed, signal=ILL)
CPU: 89ms
Apr 22 16:54:08 pizero1w systemd[1]: Starting Caddy...
Apr 22 16:54:09 pizero1w systemd[1]: caddy.service: Main process exited, code=killed, status=4/ILL
Apr 22 16:54:09 pizero1w systemd[1]: caddy.service: Failed with result 'signal'.
Apr 22 16:54:09 pizero1w systemd[1]: Failed to start Caddy.
Tried Raspberry Pi Os Lite - 64 bit verion, but it doesn’t run on the pi zero W v1.1
Ah right, this might have to do with how “armv6” and “armv7” actually both also known as “armhf”, but Cloudsmith only supports “armhf”, so we have to pick one, and we decided to push armv7 builds to Cloudsmith. So if your device requires armv6 builds (which I think it does from a quick google search), then it won’t directly work with the apt repo, unfortunately.
To work around it, you’ll need to download a build from Download Caddy instead, and follow these instructions to replace the binary the apt repo provides with the one you downloaded: Package support files for custom builds for Debian/Ubuntu/Raspbian
derrickr
(derrickr)
April 23, 2022, 7:48am
4
Thanks for your feedeback, but my problem was that I wasn’t able to get caddy running at all.
However, now following @francislavoie ’s advice, I’ve now got it running
derrickr
(derrickr)
April 23, 2022, 7:51am
5
Excellent!
Thank you @francislavoie !
I followed your advice and got it working!
Gonna tinker for a while & then post back my exact steps.
Cheers!
derrickr
(derrickr)
April 23, 2022, 8:49am
6
As suggested by @francislavoie , I downloaded the ‘Linux arm 6’ binary from Download Caddy using my PC.
I couldn’t work out the correct URL to use on curl or wget, to download the ‘Linux arm 6’ binary straight to my Raspberry Pi Zero v1.1, so I ended up using FTP to upload the downloaded ‘caddy_linux_arm6’ from my PC to my Raspberry Pi Zero v1.1
Now, with the ‘Linux arm 6’ binary on my Raspberry Pi Zero v1.1, I could follow the rest of the procedure here: Build from source — Caddy Documentation
The first command failed: dpkg-divert: error: error checking ‘/usr/bin/caddy’: Permission denied
Therefore sudo all the commands (worked for me):
sudo dpkg-divert --divert /usr/bin/caddy.default --rename /usr/bin/caddy
sudo mv ./caddy /usr/bin/caddy.custom
sudo update-alternatives --install /usr/bin/caddy caddy /usr/bin/caddy.default 10
sudo update-alternatives --install /usr/bin/caddy caddy /usr/bin/caddy.custom 50
sudo systemctl start caddy
However, Caddy still failed to start, so I then
sudo chmod 755 /usr/bin/caddy.custom
sudo systemctl status caddy
Active: active (running) since Sat 2022-04-23 08:45:02 BST; 11s ago
Main PID: 748 (caddy)
Tasks: 7 (limit: 415)
CPU: 353ms
└─748 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Apr 23 08:45:02 zero1w caddy[748]: JOURNAL_STREAM=8:30412
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.0177162,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.0801115,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.0831895,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.0900774,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Apr 23 08:45:02 zero1w systemd[1]: Started Caddy.
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.1002073,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.117115,"logger":"tls","msg":"finished cleaning storage units"}
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.121881,"msg":"serving initial configuration"}
Apr 23 08:45:02 zero1w caddy[748]: {"level":"info","ts":1650699902.124075,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x33f8410"}```
You can just right-click the Download button once you’ve made your selection and use that link directly. E.g. https://caddyserver.com/api/download?os=linux&arch=arm&arm=6&idempotency=83882779422945
Right, those steps assumed that the file already had executable permissions; FWIW, if a binary ever tells you “permission denied”, then you probably just need to do sudo chmod +x /usr/bin/caddy.custom. Using +x basically means “add executable permissions”. 755 is also fine though, in this case.
derrickr
(derrickr)
April 23, 2022, 11:38am
9
Apologies, clicked delete on last post as I made a mistake. Tried to use curl again & it worked. Guess I must’ve been doing something wrong?
Anyway, all good now
