Wildcard SSL: module not registered: dns.providers.cloudflare
Ubuntu 20.04
xcaddy build master --with github.com/caddy-dns/cloudflare@latest
sudo systemctl restart caddy
n/a
d. My complete Caddyfile:
darrenter.cyou, *.darrenter.cyou {
    root * /var/www/html/darrenter.cyou
    # Compress Response
        output file /var/log/caddy/darrenter.cyou.access.log {
            roll_size 1gb
            roll_keep 1000
            roll_keep_for 2880h
       dns cloudflare [REDACTED]
I have installed the cloudflare module via
View the result of command here
but the dns.providers.cloudflare doesn’t listed inside caddy list-modules
Full List of my list-modules
admin.api.load
admin.api.metrics
caddy.adapters.caddyfile
caddy.listeners.tls
caddy.logging.encoders.console
caddy.logging.encoders.filter
caddy.logging.encoders.filter.delete
caddy.logging.encoders.filter.ip_mask
caddy.logging.encoders.json
caddy.logging.encoders.logfmt
caddy.logging.encoders.single_field
caddy.logging.writers.discard
caddy.logging.writers.file
caddy.logging.writers.net
caddy.logging.writers.stderr
caddy.logging.writers.stdout
caddy.storage.file_system
http
http.authentication.hashes.bcrypt
http.authentication.hashes.scrypt
http.authentication.providers.http_basic
http.encoders.gzip
http.encoders.zstd
http.handlers.acme_server
http.handlers.authentication
http.handlers.encode
http.handlers.error
http.handlers.file_server
http.handlers.headers
http.handlers.map
http.handlers.metrics
http.handlers.push
http.handlers.request_body
http.handlers.reverse_proxy
http.handlers.rewrite
http.handlers.static_response
http.handlers.subroute
http.handlers.templates
http.handlers.vars
http.matchers.expression
http.matchers.file
http.matchers.header
http.matchers.header_regexp
http.matchers.host
http.matchers.method
http.matchers.not
http.matchers.path
http.matchers.path_regexp
http.matchers.protocol
http.matchers.query
http.matchers.remote_ip
http.matchers.vars
http.matchers.vars_regexp
http.reverse_proxy.selection_policies.cookie
http.reverse_proxy.selection_policies.first
http.reverse_proxy.selection_policies.header
http.reverse_proxy.selection_policies.ip_hash
http.reverse_proxy.selection_policies.least_conn
http.reverse_proxy.selection_policies.random
http.reverse_proxy.selection_policies.random_choose
http.reverse_proxy.selection_policies.round_robin
http.reverse_proxy.selection_policies.uri_hash
http.reverse_proxy.transport.fastcgi
http.reverse_proxy.transport.http
pki
tls
tls.certificates.automate
tls.certificates.load_files
tls.certificates.load_folders
tls.certificates.load_pem
tls.handshake_match.sni
tls.issuance.acme
tls.issuance.internal
tls.issuance.zerossl
tls.stek.distributed
tls.stek.standard
For references, my DNS record configured to be:
A    darrenter.cyou    {my server ip}    DNS only
A    *                         {my server ip}     DNS only
 parsing caddyfile tokens for 'tls': /etc/caddy/Caddyfile:33 - Error during parsing: getting DNS provider module named 'cloudflare': module not registered: dns.providers.cloudflare
I saw similar issue in repo of cloudflare module, the maintainer suggest to build the xcaddy with tagged release.
So I run
xcaddy build v2.2.0-rc.1 --with github.com/caddy-dns/cloudflare@latest
Instead of:
xcaddy build --with github.com/caddy-dns/cloudflare
But I still doesn’t saw cloudflare module in list-modules
Another thing I notice with this issue is, when I run xcaddy in terminal, error message occur:
go list -m: not using modules
2021/03/31 03:18:50 [ERROR] exec [go list -m]: exit status 1:
Not sure whether it cause the issue I face now.
After your built Caddy with xcaddy, did you move the resulting binary to the correct location? xcaddy doesn’t do that for you, by default it outputs it to your current directory.
Thank you for your tips.
I solved it by move the resulting binary to /usr/bin. Now dns.providers.cloudflare is listed inside output of caddy list-modules
