Wildcard SSL certificate not working aws dynamic subdomain
1. Output of caddy version:
caddy version
i installed caddy on an aws ec2 instance ubuntu using exactly what was said on the documentation page
Ubuntu 22.04.1 LTS (GNU/Linux 5.15.0-1022-aws x86_64)
Paste command here.
*.mysite, mysite {
		 dns route53 {
    max_retries 10
    aws_profile "my profile"
    access_key_id "my-profile-access-key"
    secret_access_key "my-profile-secret-key"
    token "my-profile-secret-key"
    region "eu-west-3"
        root * /var/www/mysite/public
        encode zstd gzip
         php_fastcgi unix//var/run/php/php8.2-fpm.sock
Im trying to get subdomain to work with my domain (wildcard certificate) but subdomain doesn’t generate ssl certificate
all my certificates are hosted on s3 storage so i have both s3 storage plugin and dns route 53 plugin
Jan 21 22:05:17 ip-172-31-39-194 caddy[249127]: {"level":"info","ts":1674338717.9979832,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.testlave.live"}
Jan 21 22:05:18 ip-172-31-39-194 caddy[249127]: {"level":"info","ts":1674338718.422322,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"*.testlave.live","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jan 21 22:05:18 ip-172-31-39-194 caddy[249127]: {"level":"error","ts":1674338718.7669091,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"*.testlave.live","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.testlave.live\" (usually OK if presenting also failed)"}
Jan 21 22:05:18 ip-172-31-39-194 caddy[249127]: {"level":"error","ts":1674338718.9066675,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.testlave.live","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.testlave.live] solving challenges: presenting for challenge: adding temporary record for zone \"testlave.live.\": operation error Route 53: ListHostedZonesByName, https response error StatusCode: 403, RequestID: 6563e61e-134a-4fd2-bf70-7607d883a16e, api error SignatureDoesNotMatch: The request signature we calculated does not match the signature you provided. Check your AWS Secret Access Key and signing method. Consult the service documentation for details. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/84131713/6694827993) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jan 21 22:05:20 ip-172-31-39-194 caddy[249127]: {"level":"info","ts":1674338720.8710263,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"*.testlave.live","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
Jan 21 22:05:21 ip-172-31-39-194 caddy[249127]: {"level":"error","ts":1674338721.2110147,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"*.testlave.live","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.testlave.live\" (usually OK if presenting also failed)"}
Jan 21 22:05:21 ip-172-31-39-194 caddy[249127]: {"level":"error","ts":1674338721.700836,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.testlave.live","issuer":"acme.zerossl.com-v2-DV90","error":"[*.testlave.live] solving challenges: presenting for challenge: adding temporary record for zone \"testlave.live.\": operation error Route 53: ListHostedZonesByName, https response error StatusCode: 403, RequestID: 46ad2d23-adcd-40f0-830e-8da7edda790f, api error SignatureDoesNotMatch: The request signature we calculated does not match the signature you provided. Check your AWS Secret Access Key and signing method. Consult the service documentation for details. (order=https://acme.zerossl.com/v2/DV90/order/cM01XC8kmxAyX93orxXaxQ) (ca=https://acme.zerossl.com/v2/DV90)"}
Jan 21 22:05:21 ip-172-31-39-194 caddy[249127]: {"level":"error","ts":1674338721.7011356,"logger":"tls.obtain","msg":"will retry","error":"[*.testlave.live] Obtain: [*.testlave.live] solving challenges: presenting for challenge: adding temporary record for zone \"testlave.live.\": operation error Route 53: ListHostedZonesByName, https response error StatusCode: 403, RequestID: 46ad2d23-adcd-40f0-830e-8da7edda790f, api error SignatureDoesNotMatch: The request signature we calculated does not match the signature you provided. Check your AWS Secret Access Key and signing method. Consult the service documentation for details. (order=https://acme.zerossl.com/v2/DV90/order/cM01XC8kmxAyX93orxXaxQ) (ca=https://acme.zerossl.com/v2/DV90)","attempt":4,"retrying_in":300,"elapsed":319.633461226,"max_duration":2592000}
Please help me . Im assuming the error has to do with token Id value cause i tried using both access & secret key but to no avail’
when i create my iam user,AWS gives me only access key & secret key so dont know what to put at token
If my assumptions are wrong, please correct me in the right direction
Have your read the docs for authenticating?
Might be best if you ask for help on issues for the plugin. I don’t use AWS, so I can’t do much to help.
Thanks Francis for your guidance. I have been able to get it to work
Please explain what you did to fix it.
The point of using forums for support is so that other users in the future may find answers for their questions via searching.
If you don’t explain the solution, it’ll be frustrating to people finding this thread later on.
okay sure.
So I added full route53 access to my iam profile.
i ignored the ‘token’ section in the routed3 plugin credentials .
so here is my caddy file config
email my-email@gmail.com
  storage s3 {
        host "my-bucket.s3.eu-west-3.amazonaws.com"
        bucket "my-bucket"
        access_id "My-access-key"
        secret_key "my-access-key"
        prefix "ssl"
        insecure true
        storage_clean_interval 100d
on_demand_tls {
                ask https://my-domain/domain/verify
                interval 2m
                burst 5
http:// {
redir https://{host}{uri}
*.my-domain, my-domain {
@www header_regexp www Host ^www\.(.*)$
  redir @www https://{re.www.1} 301
    dns route53 {
    max_retries 10
    aws_profile "laravel"
    access_key_id "My-access-key"
    secret_access_key "my-access-key"
    region "eu-west-3"
        root * /var/www/myfolder/public
        encode zstd gzip
https:// {
        on_demand
        encode zstd gzip
