I am building a multi-tenant web application. Clients have a default domain “UUID.cloudwebsitebuilder.cloud” but they also have the ability to add their own custom domain (default domain then redirects to the client domain). Caddy is running smoothly for me and everything works great! But! It occurred to me that I should be using a wildcard certificate for “*.cloudwebsitebuilder.cloud”. I’ve seen a few similar requests but none using the JSON config. I understand I need to get the DNS provider working for solving the ACME challenges, but that aside, how must my routes be adjusted?
Caddy is installed as a service and I’m administering it through the API only.
AWS EC2 instance running Amazon Linux
"apps": {
"http": {
"servers": {
"clients": {
"listen": [
":443"
"routes": [
"@id": "7025329f-2226-4406-8300-c405ea3ba84f",
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "vars",
"site_id": "7025329f-2226-4406-8300-c405ea3ba84f"
"handle": [
"handler": "static_response",
"headers": {
"Location": [
"https://dewpoint.com{http.request.uri.path}"
"status_code": 301
"match": [
"host": [
"www.dewpoint.com",
"7025329f-2226-4406-8300-c405ea3ba84f.cloudwebsitebuilder.cloud"
"match": [
"host": [
"dewpoint.com",
"www.dewpoint.com",
"@id": "01164256-4c2c-4d62-922f-31bcc7456c46",
"handle": [
"routes": [
"handle": [
"handler": "vars",
"site_id": "01164256-4c2c-4d62-922f-31bcc7456c46"
"handle": [
"headers": {
"Location": [
"https://01164256-4c2c-4d62-922f-31bcc7456c46.cloudwebsitebuilder.cloud{http.request.uri.path}"
"status_code": 301
"match": [
"host": [
"www.01164256-4c2c-4d62-922f-31bcc7456c46.cloudwebsitebuilder.cloud"
"match": [
"host": [
"01164256-4c2c-4d62-922f-31bcc7456c46.cloudwebsitebuilder.cloud",
"@id": "default_handler",
"handle": [
"handler": "vars",
"original_path": "{http.request.uri.path}"
"encodings": {
"gzip": {}
"handler": "encode",
"minimum_length": 0
"routes": [
"handle": [
"handler": "rewrite",
"uri": "/sites/{http.vars.site_id}/live/html{http.vars.original_path}index.html"
"handle_response": [
"match": {
"status_code": [
403
"routes": [
"handle": [
"uri": "/api/publish-page?from_proxy=true&site_id={http.vars.site_id}&path={http.request.orig_uri}"
"handler": "reverse_proxy",
"headers": {
"request": {
"set": {
"Host": [
"{http.reverse_proxy.upstream.hostport}"
"transport": {
"protocol": "http",
"tls": {}
"upstreams": [
"dial": "dashboard.cloudwebsitebuilder.cloud:443"
"headers": {
"request": {
"set": {
"Host": [
"cdn.cloudwebsitebuilder.cloud"
"upstreams": [
"dial": "cdn.cloudwebsitebuilder.cloud:80"
