I am trying to use a wildcard DNS certificate and have forward auth via Authentik for multiple subdomains. I have previously had this working but was using a new certificate for each subdomain which was not ideal. Reverse proxying works but there is no auth happening. whoami.stalepopcorn.em works as expected but completely bypasses any auth.
{"level":"info","ts":1688466003.759242,"logger":"docker-proxy","msg":"Running caddy proxy server"}
{"level":"info","ts":1688466003.7601113,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1688466003.7606738,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1688466003.7607014,"logger":"docker-proxy","msg":"Running caddy proxy controller"}
{"level":"info","ts":1688466003.761169,"logger":"docker-proxy","msg":"Start","CaddyfilePath":"/Caddyfile","LabelPrefix":"caddy","PollingInterval":30,"ProcessCaddyfile":true,"ProxyServiceTasks":true,"IngressNetworks":"[caddy]","DockerSockets":[""],"DockerCertsPath":[""],"DockerAPIsVersion":[""]}
{"level":"info","ts":1688466003.7619762,"logger":"docker-proxy","msg":"IngressNetworksMap","ingres":"map[5d3b42ca2da1edbf57a85211658c0af54b2692ef4cfdbfa1e04827c6b1171c94:true caddy:true]"}
{"level":"info","ts":1688466003.761993,"logger":"docker-proxy","msg":"Connecting to docker events","DockerSocket":""}
{"level":"info","ts":1688466003.7672575,"logger":"docker-proxy","msg":"Swarm is available","new":false}
{"level":"info","ts":1688466003.777905,"logger":"docker-proxy","msg":"Process Caddyfile","logs":"[ERROR] Removing invalid block: ambiguous site definition: stalepopcorn.me\nstalepopcorn.me {\n\treverse_proxy 192.168.90.5:3000\n}\n\n"}
{"level":"info","ts":1688466003.7779224,"logger":"docker-proxy","msg":"New Caddyfile","caddyfile":"(auth) {\n\treverse_proxy /outpost.goauthentik.io/* http://authentik_server:9000 {\n\t\theader_up Host {http.reverse_proxy.upstream.hostport}\n\t}\n\tforward_auth http://authentik_server:9000 {\n\t\turi /outpost.goauthentik.io/auth/caddy\n\t\tcopy_headers X-Authentik-Username X-Authentik-Groups X-Authentik-Email X-Authentik-Name X-Authentik-Uid X-Authentik-Jwt X-Authentik-Meta-Jwks X-Authentik-Meta-Outpost X-Authentik-Meta-Provider X-Authentik-Meta-App X-Authentik-Meta-Version authorization\n\t\ttrusted_proxies private_ranges\n\t}\n}\n*.stalepopcorn.me, stalepopcorn.me {\n\t@whoami host whoami.stalepopcorn.me\n\ttls {\n\t\tdns cloudflare randomapikey\n\t}\n\thandle @whoami {\n\t\timport auth\n\t\treverse_proxy whoami:80\n\t}\n}\nsonarr.stalepopcorn.me {\n\timport auth\n\treverse_proxy http://sonarr:8989 {\n\t\theader_up X-Real-IP {remote_host}\n\t}\n}\nplex.stalepopcorn.me {\n\treverse_proxy http://192.168.0.69:32400\n}\nauthentik.stalepopcorn.me {\n\treverse_proxy 192.168.90.6:9000\n}\ncode.stalepopcorn.me {\n\treverse_proxy 192.168.90.7:8443\n}\ndozzle.stalepopcorn.me {\n\treverse_proxy 192.168.90.10:8080\n}\nwhoami.stalepopcorn.me {\n\treverse_proxy 192.168.90.8\n}\n"}
{"level":"info","ts":1688466003.7789881,"logger":"docker-proxy","msg":"New Config JSON","json":"{\"apps\":{\"http\":{\"servers\":{\"srv0\":{\"listen\":[\":443\"],\"routes\":[{\"match\":[{\"host\":[\"authentik.stalepopcorn.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handler\":\"reverse_proxy\",\"upstreams\":[{\"dial\":\"192.168.90.6:9000\"}]}]}]}],\"terminal\":true},{\"match\":[{\"host\":[\"sonarr.stalepopcorn.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handle_response\":[{\"match\":{\"status_code\":[2]},\"routes\":[{\"handle\":[{\"handler\":\"headers\",\"request\":{\"set\":{\"Authorization\":[\"{http.reverse_proxy.header.Authorization}\"],\"X-Authentik-Email\":[\"{http.reverse_proxy.header.X-Authentik-Email}\"],\"X-Authentik-Groups\":[\"{http.reverse_proxy.header.X-Authentik-Groups}\"],\"X-Authentik-Jwt\":[\"{http.reverse_proxy.header.X-Authentik-Jwt}\"],\"X-Authentik-Meta-App\":[\"{http.reverse_proxy.header.X-Authentik-Meta-App}\"],\"X-Authentik-Meta-Jwks\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Jwks}\"],\"X-Authentik-Meta-Outpost\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Outpost}\"],\"X-Authentik-Meta-Provider\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Provider}\"],\"X-Authentik-Meta-Version\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Version}\"],\"X-Authentik-Name\":[\"{http.reverse_proxy.header.X-Authentik-Name}\"],\"X-Authentik-Uid\":[\"{http.reverse_proxy.header.X-Authentik-Uid}\"],\"X-Authentik-Username\":[\"{http.reverse_proxy.header.X-Authentik-Username}\"]}}}]}]}],\"handler\":\"reverse_proxy\",\"headers\":{\"request\":{\"set\":{\"X-Forwarded-Method\":[\"{http.request.method}\"],\"X-Forwarded-Uri\":[\"{http.request.uri}\"]}}},\"rewrite\":{\"method\":\"GET\",\"uri\":\"/outpost.goauthentik.io/auth/caddy\"},\"trusted_proxies\":[\"192.168.0.0/16\",\"172.16.0.0/12\",\"10.0.0.0/8\",\"127.0.0.1/8\",\"fd00::/8\",\"::1\"],\"upstreams\":[{\"dial\":\"authentik_server:9000\"}]}]},{\"handle\":[{\"handler\":\"reverse_proxy\",\"headers\":{\"request\":{\"set\":{\"Host\":[\"{http.reverse_proxy.upstream.hostport}\"]}}},\"upstreams\":[{\"dial\":\"authentik_server:9000\"}]}],\"match\":[{\"path\":[\"/outpost.goauthentik.io/*\"]}]},{\"handle\":[{\"handler\":\"reverse_proxy\",\"headers\":{\"request\":{\"set\":{\"X-Real-Ip\":[\"{http.request.remote.host}\"]}}},\"upstreams\":[{\"dial\":\"sonarr:8989\"}]}]}]}],\"terminal\":true},{\"match\":[{\"host\":[\"dozzle.stalepopcorn.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handler\":\"reverse_proxy\",\"upstreams\":[{\"dial\":\"192.168.90.10:8080\"}]}]}]}],\"terminal\":true},{\"match\":[{\"host\":[\"whoami.stalepopcorn.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handler\":\"reverse_proxy\",\"upstreams\":[{\"dial\":\"192.168.90.8:80\"}]}]}]}],\"terminal\":true},{\"match\":[{\"host\":[\"plex.stalepopcorn.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handler\":\"reverse_proxy\",\"upstreams\":[{\"dial\":\"192.168.0.69:32400\"}]}]}]}],\"terminal\":true},{\"match\":[{\"host\":[\"code.stalepopcorn.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handler\":\"reverse_proxy\",\"upstreams\":[{\"dial\":\"192.168.90.7:8443\"}]}]}]}],\"terminal\":true},{\"match\":[{\"host\":[\"*.stalepopcorn.me\",\"stalepopcorn.me\"]}],\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handler\":\"subroute\",\"routes\":[{\"handle\":[{\"handle_response\":[{\"match\":{\"status_code\":[2]},\"routes\":[{\"handle\":[{\"handler\":\"headers\",\"request\":{\"set\":{\"Authorization\":[\"{http.reverse_proxy.header.Authorization}\"],\"X-Authentik-Email\":[\"{http.reverse_proxy.header.X-Authentik-Email}\"],\"X-Authentik-Groups\":[\"{http.reverse_proxy.header.X-Authentik-Groups}\"],\"X-Authentik-Jwt\":[\"{http.reverse_proxy.header.X-Authentik-Jwt}\"],\"X-Authentik-Meta-App\":[\"{http.reverse_proxy.header.X-Authentik-Meta-App}\"],\"X-Authentik-Meta-Jwks\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Jwks}\"],\"X-Authentik-Meta-Outpost\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Outpost}\"],\"X-Authentik-Meta-Provider\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Provider}\"],\"X-Authentik-Meta-Version\":[\"{http.reverse_proxy.header.X-Authentik-Meta-Version}\"],\"X-Authentik-Name\":[\"{http.reverse_proxy.header.X-Authentik-Name}\"],\"X-Authentik-Uid\":[\"{http.reverse_proxy.header.X-Authentik-Uid}\"],\"X-Authentik-Username\":[\"{http.reverse_proxy.header.X-Authentik-Username}\"]}}}]}]}],\"handler\":\"reverse_proxy\",\"headers\":{\"request\":{\"set\":{\"X-Forwarded-Method\":[\"{http.request.method}\"],\"X-Forwarded-Uri\":[\"{http.request.uri}\"]}}},\"rewrite\":{\"method\":\"GET\",\"uri\":\"/outpost.goauthentik.io/auth/caddy\"},\"trusted_proxies\":[\"192.168.0.0/16\",\"172.16.0.0/12\",\"10.0.0.0/8\",\"127.0.0.1/8\",\"fd00::/8\",\"::1\"],\"upstreams\":[{\"dial\":\"authentik_server:9000\"}]}]},{\"handle\":[{\"handler\":\"reverse_proxy\",\"headers\":{\"request\":{\"set\":{\"Host\":[\"{http.reverse_proxy.upstream.hostport}\"]}}},\"upstreams\":[{\"dial\":\"authentik_server:9000\"}]}],\"match\":[{\"path\":[\"/outpost.goauthentik.io/*\"]}]},{\"handle\":[{\"handler\":\"reverse_proxy\",\"upstreams\":[{\"dial\":\"whoami:80\"}]}]}]}],\"match\":[{\"host\":[\"whoami.stalepopcorn.me\"]}]}]}],\"terminal\":true}]}}},\"tls\":{\"automation\":{\"policies\":[{\"subjects\":[\"authentik.stalepopcorn.me\",\"sonarr.stalepopcorn.me\",\"dozzle.stalepopcorn.me\",\"whoami.stalepopcorn.me\",\"plex.stalepopcorn.me\",\"code.stalepopcorn.me\"]},{\"subjects\":[\"*.stalepopcorn.me\",\"stalepopcorn.me\"],\"issuers\":[{\"challenges\":{\"dns\":{\"provider\":{\"api_token\":\"randomapikey\",\"name\":\"cloudflare\"}}},\"module\":\"acme\"},{\"challenges\":{\"dns\":{\"provider\":{\"api_token\":\"randomapikey\",\"name\":\"cloudflare\"}}},\"module\":\"zerossl\"}]}]}}}}"}
{"level":"info","ts":1688466003.7790296,"logger":"docker-proxy","msg":"Sending configuration to","server":"localhost"}
{"level":"info","ts":1688466003.7795088,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"51554","headers":{"Accept-Encoding":["gzip"],"Content-Length":["5348"],"Content-Type":["application/json"],"User-Agent":["Go-http-client/1.1"]}}
{"level":"info","ts":1688466003.7802045,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1688466003.7804182,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00011ad20"}
{"level":"info","ts":1688466003.78044,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1688466003.780462,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1688466003.7811518,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1688466003.7811913,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
{"level":"info","ts":1688466003.7812448,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1688466003.7812808,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1688466003.7812843,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.stalepopcorn.me","stalepopcorn.me","authentik.stalepopcorn.me","sonarr.stalepopcorn.me","dozzle.stalepopcorn.me","whoami.stalepopcorn.me","plex.stalepopcorn.me","code.stalepopcorn.me"]}
{"level":"info","ts":1688466003.784341,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1688466003.784455,"logger":"admin.api","msg":"load complete"}
{"level":"info","ts":1688466003.7845197,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1688466003.7845967,"logger":"docker-proxy","msg":"Successfully configured","server":"localhost"}
{"level":"info","ts":1688466003.7858076,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1688466003.7887352,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
v2.6.4 with Caddy Docker Proxy and Cloudflare DNS
Official builder image with Caddy Docker Proxy and Cloudflare DNS plugins, running in Docker
Ubuntu 23.04 (GNU/Linux 6.2.0-24-generic x86_64)
Docker CE 24.0.2
docker compose up -d
image: caddy:cloudflare
#image: lucaslorentz/caddy-docker-proxy:ci-alpine
- 443:443
- CADDY_INGRESS_NETWORKS=caddy
- CADDY_DOCKER_CADDYFILE_PATH=/Caddyfile
- caddy
- ./appdata/caddy/data:/data
- ./appdata/caddy/config:/config
- ./appdata/caddy/Caddyfile:/Caddyfile
(auth) {
# always forward outpost path to actual outpost
# forward authentication to outpost
# capitalization of the headers is important, otherwise they will be empty
# optional, in this config trust all private ranges, should probably be set to the outposts IP
@home host stalepopcorn.me
handle @home {
revers_proxy homepage:3000
handle @whoami {
import auth
Old working Caddyfile. I was using one block per service before attempting wildcard certs. I can move the auth parts to a snippet and us ‘import’ in each block and that works as well.
copy_headers X-Authentik-Username X-Authentik-Groups X-Authentik-Email X-Authentik-Name X-Authentik-Uid X-Authentik-Jwt X-Authentik-Meta-Jwks X-Authentik-Meta-Outpost X-Authentik-Meta-Provi>
# actual site configuration below, for example
reverse_proxy {{upstreams}}
