Why is json setup so difficult?
1. Output of caddy version:
Paste command here.
curl “http://localhost:2019/load” -H “Content-Type: application/json” -d @caddy.json
“logging”: {
“logs”: {
“writer”: {
“stdout”: {
“output”: “stdout”
“stderr”: {
“output”: “stderr”
Paste your config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I can’t understand the json config
{“error”:“loading config: loading new config: setting up custom log ‘’: loading log writer module: module name not specified with key ‘output’ in map[stderr:map[output:stderr] stdout:map[output:stdout]]”}
root@test:~/application# journalctl -u caddy.service -f --output cat
{“level”:“info”,“ts”:1677039993.7283962,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc00043b420”}
2023-02-22 04:26:33.728396337 +0000 UTC m=+16.059547109 write error: error getting log file info: stat /root/log/caddy.log: permission denied
{“level”:“info”,“ts”:1677039993.7291415,“logger”:“http.log”,“msg”:“server running”,“name”:“front”,“protocols”:[“h1”,“h2”,“h3”]}
2023-02-22 04:26:33.729141377 +0000 UTC m=+16.060292159 write error: error getting log file info: stat /root/log/caddy.log: permission denied
{“level”:“info”,“ts”:1677039993.729247,“logger”:“tls.cache.maintenance”,“msg”:“stopped background certificate maintenance”,“cache”:“0xc0003a0690”}
{“level”:“info”,“ts”:1677039993.729362,“msg”:“autosaved config (load with --resume flag)”,“file”:“/var/lib/caddy/.config/caddy/autosave.json”}
{“level”:“info”,“ts”:1677039993.7294462,“logger”:“admin.api”,“msg”:“load complete”}
{“level”:“info”,“ts”:1677039993.7326043,“logger”:“admin”,“msg”:“stopped previous server”,“address”:“localhost:2019”}
{“level”:“error”,“ts”:1677039997.7891026,“logger”:“http.handlers.reverse_proxy”,“msg”:“aborting with incomplete response”,“error”:“write tcp 158.247.219.96:80->162.158.170.85:11744: write: broken pipe”}
2023-02-22 04:26:37.789102665 +0000 UTC m=+20.120253448 write error: error getting log file info: stat /root/log/caddy.log: permission denied
You can use caddy adapt to change a Caddyfile to json, documentation will help you to understand how json config is structured. I’m using a phone right now, so I can’t really tell you what’s wrong the config.
I’d also recommend looking at the crash course style wiki post done by Matt Holt:
