Why is caddy trying to start on port 80?
v2.0.0-beta.13 h1:QL0JAepFvLVtOatABqniuDRQ4HmtvWuuSWZW24qVVtk=
./caddy run Caddyfile
Ubuntu 18.04
d. My complete Caddyfile:
        # hass
        http://hass.lcl.info:9999 {
            reverse_proxy / http://172.18.0.5 {
Caddy tries to start on port 80 despite not having anything to serve on that port.
Alternatively, it may want to start on port 80 to provide a Let’s Encrypt challenge endpoint but there are not HTTPS services in the Caddyfile
2020/01/23 13:39:39.260 INFO    using adjacent Caddyfile
2020/01/23 13:39:39.262 INFO    admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["localhost:2019"]}
2020/01/23 13:39:39.262 INFO    http    enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2020/01/23 13:39:39.263 INFO    http    enabling automatic TLS certificate management   {"domains": ["hass.lcl.info"]}
2020/01/23 14:39:39 [INFO][cache:0xc0003b3e00] Started certificate maintenance routine
run: loading initial config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: address already in use
That looks like a bug. Would you please file an issue on GitHub so I can fix it? Thanks for using Caddy 2 while it’s still in beta!
EDIT: If you’re landing here from a search, see my reply below. You’re probably not experiencing a bug. Caddy always listens on port 80 to redirect HTTP to HTTPS unless you disable that.
@matt: done (Caddy trying to start on port 80 without any HTTPS sites defined · Issue #2998 · caddyserver/caddy · GitHub)
Thanks – for anyone following along at home, I pushed a commit here: httpcaddyfile: Skip hosts from auto-https when http:// scheme (fix #2… · caddyserver/caddy@8b2ad61 · GitHub - which should fix it.
Edit: For everyone finding this in search results, you’re probably seeing Caddy trying to redirect HTTP to HTTPS, which requires the HTTP port (80); not this particular bug, which is where Caddy was trying to use port 80 even without an HTTPS site.
Thank you very much @matt .
@matt, This issue seems to be happening again. I’m trying to start localhost:16655
caddyfile.json
  "logging": {
    "logs": {
      "log0": {
        "writer": {
          "filename": "d:\\caddy\\access564.log",
          "output": "file"
        "include": [
          "http.log.access.log0"
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":16655"
          "routes": [
              "match": [
                  "host": [
                    "localhost"
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "body": "this is a caddy2 server",
                          "handler": "static_response"
              "terminal": true
          "logs": {
            "logger_names": {
              "localhost:16655": "log0"
load and response
D:\caddy>curl localhost:2019/load -X POST -H "Content-Type: application/json" -d @caddyfile.json
  "error": "loading config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted."
You’re hitting the local Auto HTTPS rules, it’s trying to set up an HTTP->HTTPS redirect for you.
Use the global option http_port to change it to some other port or turn off automatic redirects JSON Config Structure - Caddy Documentation
