Why are HTTP versions being skipped?
Want to know what these log entries about skipping HTTP versions mean. Why is HTTP/1 and /2 skipped? What is port 80 about? I don’t use port 80 anywhere.
log output:
2026/09/01 17:36:40 e[34mINFOe[0m http.auto_https enabling automatic HTTP->HTTPS redirects {“server_name”: “srv0”}
2026/09/01 17:36:40 e[34mINFOe[0m http.log server running {“name”: “srv0”, “protocols”: [“h2”, “h1”]}
2026/09/01 17:36:40 e[33mWARNe[0m http HTTP/2 skipped because it requires TLS {“network”: “tcp”, “addr”: “:80”}
2026/09/01 17:36:40 e[33mWARNe[0m http HTTP/3 skipped because it requires TLS {“network”: “tcp”, “addr”: “:80”}
2026/09/01 17:36:40 e[34mINFOe[0m http.log server running {“name”: “remaining_auto_https_redirects”, “protocols”: [“h1”, “h2”, “h3”]}
v2.11.4
Windows
How is this diff from #4?
	#log stdout
	log caddy-log {
		output file caddy.log {
			roll_local_time
		format console {
			time_format wall
			time_local
	email blah@blah.net
	default_sni somedomain.com
	servers :8443 {
		protocols h2 h1
Type here
It says it right in the log output:
Where do you see HTTP/1 being skipped?
Those messages are expected with Caddy’s automatic HTTPS behavior. Port 80 is being used for the HTTP → HTTPS redirect server, even if you didn’t explicitly configure a listener on port 80.
HTTP/2 and HTTP/3 require TLS, so Caddy skips those protocols on :80 and keeps HTTP/1 there for the redirect. The later log entry showing h1, h2, and h3 is the actual HTTPS server. So these warnings don’t indicate that HTTP/2 or HTTP/3 is broken—they’re just telling you those protocols aren’t applicable to the non-TLS redirect listener.
Thanks much, Lucas, for the details.
