Why are duration and duration_ms different (besides scale)?
Based on the documentation, duration_ms is the same as duration but in ms. However, I’m seeing differences in the values, for example (these are each on the same request):
"duration": 0.001472462,
"duration_ms": 1.440152,
"duration": 0.013516455,
"duration_ms": 13.495985000000001,
So just trying to understand what each is actually representing and if maybe the documentation is incorrect?
Please show your config. Where are you getting these values from?
The difference is sub-millisecond, it’s probably just the amount of time it took between each getting computed. They’re computed separately, from the moment in time they’re invoked.
    admin 127.0.0.1:2019 {
        output stdout
        format json
        level INFO
    servers {
        metrics
example.com {
        output stdout
    log_append duration_ms {rp.duration_ms}
    reverse_proxy 127.0.0.1:8080 {
        header_up Host localhost
I guess that makes sense but also doesn’t in that the duration should be the duration regardless of when it’s computed.
	start := time.Now()
	defer func() {
		// total proxying duration, including time spent on LB and retries
		repl.Set("http.reverse_proxy.duration", time.Since(start))
		repl.Set("http.reverse_proxy.duration_ms", time.Since(start).Seconds()*1e3) // multiply seconds to preserve decimal (see #4666)
The times are calculated on separate lines of code so there would be a tiny difference in their values. Sure we could hoist time.Since(start) to be calculated once but it doesn’t really matter.
