:8080 {
root /var/www
gzip
log stdout
errors stdout
basicauth admin {$BASICAUTH_PASSWORD} {
/index.php
/config/
/js/
/core/
/tmp/
/vendor/
/plugins/
/libs/
/misc/
/lang/
fastcgi / 127.0.0.1:9000 php
rewrite {
if_op or
if {path} has config.ini.php
if {path} has install.php
if {path} has .md
if {path} has .text
if {path} has .json
if {path} has .lock
to /403
status 403 /403
:8080 {
root /var/www
gzip
log stdout
errors stdout
not /piwik.php
not /piwik.js
rewrite {
if_op or
to /403
status 403 /403
Is there any other sane way to do this? Not playing around with proxy workarounds etc. As fastcgi doesn’t support a without a rewrite solution isn’t that simply.
Don’t know about proxy workarounds, but other than this, the only method I know is to use redirects to bounce clients between a “secure” subdomain vhost with a blanket basicauth and an “insecure” default domain, using if statements to check the requested URI.
I really like the suggestion you linked for exception logic in the basic auth directive though! I’d like to see something like this:
basicauth / user pass {
except /piwik.php
except /piwik.js
Creates a very clear intent to declare a basepath to secure and then specify exceptions. To let you secure by default but flag out known resources that are OK to share would be quite useful, especially when the contents of the web root might change.
The wider problem here is present for all directives: right now, most Caddy directives operate on a base path that the request has to match, but Caddy really needs a better, standardized way to do request matching so that it can match on more than just a base path.
I proposed a couple related things in an issue once but I only implemented #2. I still feel like something similar to #1 is needed to make Caddy really powerful/useful for power users (note that Caddy’s initial target audience is for more simple use cases, but I want to bring Caddy to more advanced sites).
Apart from the concept of opening a block in the middle of a one-liner directive seeming odd to me, which might just be due to being used to how Caddyfiles are already… That sounds like it would be absolutely wonderful and I can think of two or three common-enough use cases off the top of my head that it would solve without the need for weird workarounds.
edit: After reading through the issue, which seems to have been well discussed, it seems to me like getting this kind of power in the Caddyfile syntax without complexity is chasing an optimistic ideal.
