Which files needs to be synced between a cluster
Hi, I have multiple caddy servers running in conjunction. I have a couple questions.
1- i am using on-demand-ssl and i want to sync the ssl certificates between them so every node doesn’t generate a cert for the same domain. do i only sync the certificates folder or the entire caddy’s data folder?
2- is it possible the child nodes delegates requests to the master node that requires a certificate to be generated for that request?
Any responses are greatly appreciated. TYIA
Use distributed storage, like an RDBMS, Redis, or NATS. It’s more robust for multi-node deployment.
I don’t understand what you mean here.
