Which AWS policies are required for tls.dns.route53 plugin?
Hi, everyone. I’m using tls.dns.route53 plugin for Caddy.
My caddy config is:
prometheus.domain.name {
  prometheus
  gzip
      dns route53
  proxy / localhost:9090 {
      except /health
  log /var/log/caddy/access.log {
      rotate_size 300
      rotate_age 60
      rotate_keep 60
      rotate_compress
  errors /var/log/caddy/errors.log {
      rotate_size 300
      rotate_age 60
      rotate_keep 60
      rotate_compress
Caddy is running on EC2 AWS instance. I’m interested in which IAM policy need to tls.dns.route53 plugin. I tried to look to GoDocs here but unfortunately, doesn’t find this information.
It’s not a good practice to give all permissions for route53 and route53 domains to instance role. So any help will be appreciated.
Hi @hobot,
I don’t know if anyone here can supply the exact answer to your question, but I believe the AWS documentation you’re looking for is here:
And you can go through the Go code here and look for any calls to the route53 object to get an idea for which ones are in use:
