Where do i put my static files?!?!
The problem I’m having:
I’ve just installed and set up a caddy server, however I can’t figure out how to place my static files. I’m currently stuck with this:
What I’ve tried:
I’ve tried making a var/www/html directory with my files countless times and set the root in the configuration to point at it, only to get " This (url) page can’t be found. No webpage was found for the web address: (url)"
any help?
You need to change your Caddyfile to point to where you want your files.
Please completely fill out the help topic template as per the forum rules.
