1. Caddy version
Caddy v2
Fedora Server 35, podman version 3.4.7
I use podman to create Caddy container and assign it a bridged network.
podman run --network mybridge --name caddy -d -p 80:80 -p 443:443 -v Caddyfile:/etc/caddy/Caddyfile caddy:latest
And I used podman to create a fpm tag WordPress using the following command. The container wordpress and Caddy are in a same bridged network.
podman run --network mybridge --name wordpress -d -v ./wordpress_volume/html:/var/www/html wordpress:fpm
c. My complete Caddyfile
example.com
reverse_proxy wordpress:9000
root * /var/www/html
I hope to visit example.com to be able to see the wordpress installer, but it doesn’t. Also curl doesn’t get any information on the host.
chrome shows error code. HTTP ERROR 502.
caddy logs
{"level":"info","ts":1652022268.3539407,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1652022268.3554807,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":1}
{"level":"info","ts":1652022268.3562734,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1652022268.3563845,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1652022268.356401,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1652022268.3566067,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x40002a75e0"}
{"level":"info","ts":1652022268.3567123,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1652022268.3567233,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["[example.com"]}
{"level":"info","ts":1652022268.357134,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1652022268.357493,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1652022268.3575084,"msg":"serving initial configuration"}
{"level":"error","ts":1652022282.2875233,"logger":"http.log.error","msg":"read tcp 10.89.0.3:39894->10.89.0.2:9000: read: connection reset by peer","request":{"remote_ip":"10.89.0.3","remote_port":"53606","proto":"HTTP/2.0","method":"GET","host":"http://example.com","uri":"/","headers":{"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Dnt":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Accept-Language":["zh-CN,zh-TW;q=0.9,zh;q=0.8,en-US;q=0.7,en;q=0.6"],"Sec-Ch-Ua":["\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"101\", \"Google Chrome\";v=\"101\""],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.54 Safari/537.36"],"Upgrade-Insecure-Requests":["1"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":[],"Purpose":["prefetch"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Dest":["document"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"example.com"}},"duration":0.001114922,"status":502,"err_id":"rp11p6war","err_trace":"reverseproxy.statusError (reverseproxy.go:1196)"}
wordpress logs
[08-May-2022 15:04:24] NOTICE: fpm is running, pid 1
[08-May-2022 15:04:24] NOTICE: ready to handle connections
I think this is a stupid question. I try to use wordpress:latest with apache, and use caddy’s reverse proxy to get to the installation page. Tried using other ports as well, didn’t work. and some other attempts.
