When adding domain name to caddyfile i lose connectivity
when i add my domain name (stream.sargtv.com) to the caddyfile replacing :80 i can no longer connect to the domain on any browser, curl localhost and curl stream.sargtv.com both return blank.
curl -vl stream.sargtv.com returns
 Connected to stream.sargtv.com (140.238.134.56) port 80 (#0)
> GET / HTTP/1.1
> Host: stream.sargtv.com
> User-Agent: curl/7.81.0
< Connection: close
< Location: https://stream.sargtv.com/
< Server: Caddy
< Date: Mon, 31 Jul 2023 03:17:29 GMT
< Content-Length: 0
removing the domain name brings me to caddy’s start page like normal. this all started after an attempted reverse proxy to localhost to run an owncast server.
{"level":"info","ts":1690771064.5413632,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003c5e30"}
Jul 31 02:37:44 lucidstreamsite caddy[790]: {"level":"info","ts":1690771064.5414708,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Jul 31 02:37:44 lucidstreamsite caddy[790]: {"level":"info","ts":1690771064.5414808,"logger":"admin.api","msg":"shutdown complete","exit_code":0}
Jul 31 02:37:44 lucidstreamsite systemd[1]: caddy.service: Deactivated successfully.
Jul 31 02:37:55 lucidstreamsite systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
-- Boot c3d807f95563490ab1165ec054b64822 --
Jul 31 02:39:42 lucidstreamsite systemd[1]: Starting Caddy...
Jul 31 02:39:44 lucidstreamsite caddy[798]: caddy.HomeDir=/var/lib/caddy
Jul 31 02:39:44 lucidstreamsite caddy[798]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jul 31 02:39:44 lucidstreamsite caddy[798]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jul 31 02:39:44 lucidstreamsite caddy[798]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jul 31 02:39:44 lucidstreamsite caddy[798]: caddy.Version=v2.6.4 h1:2hwYqiRwk1tf3VruhMpLcYTg+11fCdr8S3jhNAdnPy8=
Jul 31 02:39:44 lucidstreamsite caddy[798]: runtime.GOOS=linux
Jul 31 02:39:44 lucidstreamsite caddy[798]: runtime.GOARCH=amd64
Jul 31 02:39:44 lucidstreamsite caddy[798]: runtime.Compiler=gc
Jul 31 02:39:44 lucidstreamsite caddy[798]: runtime.NumCPU=2
Jul 31 02:39:44 lucidstreamsite caddy[798]: runtime.GOMAXPROCS=2
Jul 31 02:39:44 lucidstreamsite caddy[798]: runtime.Version=go1.20
Jul 31 02:39:44 lucidstreamsite caddy[798]: os.Getwd=/
Jul 31 02:39:44 lucidstreamsite caddy[798]: LANG=C.UTF-8
Jul 31 02:39:44 lucidstreamsite caddy[798]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Jul 31 02:39:44 lucidstreamsite caddy[798]: NOTIFY_SOCKET=/run/systemd/notify
Jul 31 02:39:44 lucidstreamsite caddy[798]: HOME=/var/lib/caddy
Jul 31 02:39:44 lucidstreamsite caddy[798]: LOGNAME=caddy
Jul 31 02:39:44 lucidstreamsite caddy[798]: USER=caddy
Jul 31 02:39:44 lucidstreamsite caddy[798]: INVOCATION_ID=a2c5085deb4a42f896bf9c64549b0be2
Jul 31 02:39:44 lucidstreamsite caddy[798]: JOURNAL_STREAM=8:20232
Jul 31 02:39:44 lucidstreamsite caddy[798]: SYSTEMD_EXEC_PID=798
Jul 31 02:39:44 lucidstreamsite caddy[798]: {"level":"info","ts":1690771184.8383262,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jul 31 02:39:44 lucidstreamsite caddy[798]: Error: adapting config using caddyfile: server block 0, key 0 (:stream.sargtv.com): determining listener address: parsing key: invalid port 'stream.sargtv.com': strconv.Atoi: parsing "stream.sargtv.com": invalid syntax
Jul 31 02:39:44 lucidstreamsite systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jul 31 02:39:44 lucidstreamsite systemd[1]: caddy.service: Failed with result 'exit-code'.
Jul 31 02:39:44 lucidstreamsite systemd[1]: Failed to start Caddy.
Jul 31 02:40:00 lucidstreamsite systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Jul 31 02:40:09 lucidstreamsite systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Jul 31 02:40:16 lucidstreamsite systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Jul 31 02:41:22 lucidstreamsite systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
-- Boot 1b6dee563fa44537ab2d2ca646fa0c05 --
Jul 31 02:43:14 lucidstreamsite systemd[1]: Starting Caddy...
Jul 31 02:43:16 lucidstreamsite caddy[802]: caddy.HomeDir=/var/lib/caddy
Jul 31 02:43:16 lucidstreamsite caddy[802]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jul 31 02:43:16 lucidstreamsite caddy[802]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jul 31 02:43:16 lucidstreamsite caddy[802]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jul 31 02:43:16 lucidstreamsite caddy[802]: caddy.Version=v2.6.4 h1:2hwYqiRwk1tf3VruhMpLcYTg+11fCdr8S3jhNAdnPy8=
Jul 31 02:43:16 lucidstreamsite caddy[802]: runtime.GOOS=linux
Jul 31 02:43:16 lucidstreamsite caddy[802]: runtime.GOARCH=amd64
Jul 31 02:43:16 lucidstreamsite caddy[802]: runtime.Compiler=gc
Jul 31 02:43:16 lucidstreamsite caddy[802]: runtime.NumCPU=2
Jul 31 02:43:16 lucidstreamsite caddy[802]: runtime.GOMAXPROCS=2
Jul 31 02:43:16 lucidstreamsite caddy[802]: runtime.Version=go1.20
Jul 31 02:43:16 lucidstreamsite caddy[802]: os.Getwd=/
Jul 31 02:43:16 lucidstreamsite caddy[802]: LANG=C.UTF-8
Jul 31 02:43:16 lucidstreamsite caddy[802]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Jul 31 02:43:16 lucidstreamsite caddy[802]: NOTIFY_SOCKET=/run/systemd/notify
Jul 31 02:43:16 lucidstreamsite caddy[802]: HOME=/var/lib/caddy
Jul 31 02:43:16 lucidstreamsite caddy[802]: LOGNAME=caddy
Jul 31 02:43:16 lucidstreamsite caddy[802]: USER=caddy
Jul 31 02:43:16 lucidstreamsite caddy[802]: INVOCATION_ID=ec9090155e9848ceb3b93a5941938c7d
Jul 31 02:43:16 lucidstreamsite caddy[802]: JOURNAL_STREAM=8:20656
Jul 31 02:43:16 lucidstreamsite caddy[802]: SYSTEMD_EXEC_PID=802
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771396.9988472,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0009801,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0924718,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0928228,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0934465,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0937028,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0948772,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.095159,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.095329,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["stream.sargtv.com"]}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0957837,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002f93b0"}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.0959716,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.2822287,"logger":"tls","msg":"finished cleaning storage units"}
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.291546,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jul 31 02:43:17 lucidstreamsite systemd[1]: Started Caddy.
Jul 31 02:43:17 lucidstreamsite caddy[802]: {"level":"info","ts":1690771397.2929223,"msg":"serving initial configuration"}
Jul 31 02:45:00 lucidstreamsite systemd[1]: Reloading Caddy...
Jul 31 02:45:00 lucidstreamsite caddy[1207]: {"level":"info","ts":1690771500.5891852,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.591366,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"48876","headers":{"Accept-Encoding":["gzip"],"Cache-Control":["must-revalidate"],"Content-Length":["289"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5925922,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.592718,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5927339,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5928829,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5929096,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5929356,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5929418,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["stream.sargtv.com"]}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5932305,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002f6310"}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5941997,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0002f93b0"}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.594608,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.594939,"logger":"admin.api","msg":"load complete"}
Jul 31 02:45:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690771500.5970824,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Jul 31 02:45:00 lucidstreamsite systemd[1]: Reloaded Caddy.
Jul 31 03:01:00 lucidstreamsite systemd[1]: Reloading Caddy...
Jul 31 03:01:00 lucidstreamsite caddy[1242]: {"level":"info","ts":1690772460.5769367,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jul 31 03:01:00 lucidstreamsite caddy[1242]: {"level":"warn","ts":1690772460.5796132,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5816262,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"57526","headers":{"Accept-Encoding":["gzip"],"Cache-Control":["must-revalidate"],"Content-Length":["452"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5831552,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5840733,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002f8c40"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5840907,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.584127,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5843441,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5843692,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.584394,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5843997,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["stream.sargtv.com"]}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.584759,"logger":"tls.obtain","msg":"acquiring lock","identifier":"stream.sargtv.com"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5850167,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0002f6310"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5853353,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5857637,"logger":"admin.api","msg":"load complete"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5877268,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5895326,"logger":"tls.obtain","msg":"lock acquired","identifier":"stream.sargtv.com"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5896423,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"stream.sargtv.com"}
Jul 31 03:01:00 lucidstreamsite systemd[1]: Reloaded Caddy.
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5971093,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["stream.sargtv.com"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
Jul 31 03:01:00 lucidstreamsite caddy[802]: {"level":"info","ts":1690772460.5973208,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["stream.sargtv.com"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":"caddy@zerossl.com"}
Jul 31 03:01:01 lucidstreamsite caddy[802]: {"level":"info","ts":1690772461.0136163,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"stream.sargtv.com","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jul 31 03:01:01 lucidstreamsite caddy[802]: {"level":"error","ts":1690772461.3763316,"logger":"http.acme_client","msg":"challenge failed","identifier":"stream.sargtv.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"140.238.134.56: Error getting validation data","instance":"","subproblems":[]}}Jul 31 03:01:01 lucidstreamsite caddy[802]: {"level":"error","ts":1690772461.3768954,"logger":"http.acme_client","msg":"validating authorization","identifier":"stream.sargtv.com","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"140.238.134.56: Error getting validation data","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/112912054/10037102414","attempt":1,"max_attempts":3}
Jul 31 03:01:02 lucidstreamsite caddy[802]: {"level":"info","ts":1690772462.4956481,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"stream.sargtv.com","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jul 31 03:01:02 lucidstreamsite caddy[802]: {"level":"info","ts":1690772462.5795732,"logger":"http","msg":"served key authentication","identifier":"stream.sargtv.com","challenge":"http-01","remote":"18.224.59.97:57518","distributed":false}
Jul 31 03:01:02 lucidstreamsite caddy[802]: {"level":"info","ts":1690772462.6091626,"logger":"http","msg":"served key authentication","identifier":"stream.sargtv.com","challenge":"http-01","remote":"66.133.109.36:41337","distributed":false}Jul 31 03:01:02 lucidstreamsite caddy[802]: {"level":"info","ts":1690772462.6485097,"logger":"http","msg":"served key authentication","identifier":"stream.sargtv.com","challenge":"http-01","remote":"34.220.72.246:40252","distributed":false}Jul 31 03:01:02 lucidstreamsite caddy[802]: {"level":"info","ts":1690772462.8480728,"logger":"http.acme_client","msg":"authorization finalized","identifier":"stream.sargtv.com","authz_status":"valid"}
Jul 31 03:01:02 lucidstreamsite caddy[802]: {"level":"info","ts":1690772462.8481166,"logger":"http.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/112912054/10037102714"}
Jul 31 03:01:06 lucidstreamsite caddy[802]: {"level":"info","ts":1690772466.012773,"logger":"http.acme_client","msg":"successfully downloaded available certificate chains","count":1,"first_url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/fadf668f9f003fe6455106c40aa89c4db165"}
Jul 31 03:01:06 lucidstreamsite caddy[802]: {"level":"info","ts":1690772466.0133183,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"stream.sargtv.com"}
Jul 31 03:01:06 lucidstreamsite caddy[802]: {"level":"info","ts":1690772466.0133557,"logger":"tls.obtain","msg":"releasing lock","identifier":"stream.sargtv.com"}
Canonical-Ubuntu-22.04-2023.06.30-0 running on an oracle cloud vm
# domain name.
stream.sargtv.com {
        root * /usr/share/caddy
        # php_fastcgi localhost:9000
Hi, thanks for filling out the template!
That is working correctly. Caddy is simply redirecting your client to use HTTPS instead of HTTP.
Try using curl -vL for your command and you should see content. If not, then there’s probably some sort of networking misconfiguration, like maybe your firewall doesn’t have port 443 open.
That would be consistent with this log message:
	"level": "error",
	"ts": 1690772461.3763316,
	"logger": "http.acme_client",
	"msg": "challenge failed",
	"identifier": "stream.sargtv.com",
	"challenge_type": "tls-alpn-01",
	"problem": {
		"type": "urn:ietf:params:acme:error:connection",
		"title": "",
		"detail": "140.238.134.56: Error getting validation data",
		"instance": "",
		"subproblems": []
Caddy was still able to get a certificate using port 80, but you’ll need to make sure port 443 is open to your host.
do you know how i can do that on linux ubuntu? its odd to me that this was working before and just quit after an attempted reverse proxy.
Before you were only accessing it over port 80. Caddy’s default is 443 when you give it a domain name.
Sorry, but I’m not really sure how to help beyond that. I can help with Caddy stuff, but if you have a port blocked on your infrastructure, it might be on your system or it might be a firewall or some other network box, who knows. You’ll have to figure out why the port is blocked.
ok, i managed to fix this by adding port 443 into the iptables on ubuntu.
now my issue is that it was all working a few hours ago. i havent touched it and now its giving http error 502
That means your proxy backend/app isn’t responding.
