1. Output of caddy version:
v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
Use systemctl enable caddy, systemctl start caddy
NAME=“Ubuntu”
VERSION=“18.04.6 LTS (Bionic Beaver)” systemd
/usr/bin/caddy
# caddy.service
# for your installation.
Type=notify
order reverse_proxy before route
admin off
level ERROR
:443, mywebsite.com {
ciphers TLS_AES_256_GCM_SHA384 TLS_AES_128_GCM_SHA256 TLS_CHACHA20_POLY1305_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
curves x25519 secp521r1 secp384r1 secp256r1
alpn http/1.1 h2
@tws {
header Connection *Upgrade*
header Upgrade websocket
path /apathname }
reverse_proxy @tws 127.0.0.1:2022
@host {
host mywebsite.com }
route @host {
file_server {
root /var/www/html }
It’s said /etc/caddy is read-only although:
/etc/caddy# ll
total 16
drwxrwxr-x 3 caddy caddy 4096 Oct 8 09:14 ./
drwxr-xr-x 86 root root 4096 Oct 8 02:17 ../
drwxrwxr-x 3 caddy caddy 4096 Feb 22 2022 .config/
-rw-rw-r-- 1 caddy caddy 1119 Oct 8 09:14 Caddyfile
{"level":"error","ts":1665220447.3730838,"logger":"tls","msg":"job failed","error":"mywebsite.com: obtaining certificate: failed storage check: mkdir /etc/caddy/.local: read-only file system - storage is probably misconfigured"}
{"level":"error","ts":1665220447.4814124,"msg":"unable to autosave config","file":"/etc/caddy/.config/caddy/autosave.json","error":"open /etc/caddy/.config/caddy/autosave.json: read-only file system"}
{"level":"error","ts":1665220447.481637,"logger":"tls","msg":"job failed","error":"mywebsite.com: obtaining certificate: failed storage check: mkdir /etc/caddy/.local: read-only file system - storage is probably misconfigured"}
{"level":"error","ts":1665222732.764062,"msg":"unable to autosave config","file":"/etc/caddy/.config/caddy/autosave.json","error":"open /etc/caddy/.config/caddy/autosave.json: read-only file system"}
{"level":"error","ts":1665222732.7723339,"logger":"tls","msg":"job failed","error":"mywebsite.com: obtaining certificate: failed storage check: mkdir /etc/caddy/.local: read-only file system - storage is probably misconfigured"}
{"level":"error","ts":1665222732.7731318,"logger":"tls","msg":"job failed","error":"mywebsite.com: obtaining certificate: failed storage check: mkdir /etc/caddy/.local: read-only file system - storage is probably misconfigured"}
{"level":"error","ts":1665222942.4845963,"msg":"unable to autosave config","file":"/etc/caddy/.config/caddy/autosave.json","error":"open /etc/caddy/.config/caddy/autosave.json: read-only file system"}
{"level":"error","ts":1665222942.492277,"logger":"tls","msg":"job failed","error":"mywebsite.com: obtaining certificate: failed storage check: mkdir /etc/caddy/.local: read-only file system - storage is probably misconfigured"}
{"level":"error","ts":1665222942.4925766,"logger":"tls","msg":"job failed","error":"mywebsite.com: obtaining certificate: failed storage check: mkdir /etc/caddy/.local: read-only file system - storage is probably misconfigured"}
Tried to give w permission to caddy:caddy for /etc/caddy
