Error from startup: 2016/09/18 13:15:42 /etc/caddy/Caddyfile:5 - Parse error: Unknown directive ‘nextcloud.mydomain.com’
:443
tls alex@mydomin.com
nextcloud.mydomain.com {
log /var/log/caddy/nextcloud_access.log
root /var/www/nextcloud
fastcgi / unix:/run/php-fpm/www.sock php {
env PATH /bin
rewrite {
r ^/index.php/.*$
to /index.php?{query}
# client support (e.g. os x calendar / contacts)
redir /.well-known/carddav /remote.php/carddav 301
redir /.well-known/caldav /remote.php/caldav 301
# remove trailing / as it causes errors with php-fpm
rewrite {
r ^/remote.php/(webdav|caldav|carddav)(\/?)$
to /remote.php/{1}
rewrite {
r ^/remote.php/(webdav|caldav|carddav)/(.+)(\/?)$
to /remote.php/{1}/{2}
# .htacces / data / config / ... shouldn't be accessible from outside
rewrite {
r ^/(?:\.htaccess|data|config|db_structure\.xml|README)
status 403
header / Strict-Transport-Security "31536000"
