So basically I have caddy setup serving a static site, in my dns records I have both www.aaronrodrigues.com and aaronrodrigues.com pointing to my server. However if I access www.aaronrodrigues.com, I get an SSL HANDSHAKE FAILED error but when I access aaronrodrigues.com I can access my website fine. Not sure whats going on, any help would be appreciated.
Unable to get logs since I ran caddy using caddy start
v2.8.4
sudo apt update
sudo apt install caddy
Ubuntu 22.04 LTS arm64 24GB RAM
sudo caddy start
aaronrodrigues.com {
root * /var/www/html
handle_errors {
rewrite * /{http.error.status_code}.html
