I would like to share the configuration I use for webtrees genealogy application. In webtrees versions prior to 1.7.11, the configuration required a small modification to includes/session.php, but thankfully this is no longer the case.
The configuration was originally provided to me by @abiosoft
https://yoursite.com {
tls your@email.com
root /var/www/webtrees
fastcgi / unix:/var/run/php-fpm/php-fpm.sock php
internal /forbidden
rewrite {
r ^/data
to /forbidden
log /var/log/www/access.log {
rotate_size 50
rotate_age 7
rotate_keep 5
errors /var/log/www/error.log {
rotate_size 50
rotate_age 7
rotate_keep 5
