With HAProxy, I can do something like this:
acl is_websocket hdr(Upgrade) -i WebSocket
use_backend ws if is_websocket
I need to be able to have the websocket server on the root of the domain, but I can’t seem to get it to work with Caddy. Is there somekind of conditional to allow any other connection to / go through to php while ones with the upgrade header get proxied to my websocket server (at :8888)?
Thanks
Edit: found that I can do the following to make it work…
rewrite / {
if {>Connection} is Upgrade
if {>Upgrade} is websocket
to /websocket
proxy /websocket websocket:8888 {
without /websocket
websocket
