dallas007
(dallas007)
1
Hi there,
I’m using Caddy v2.1.
The issue in Chrome Console is:
'wss://10.10.10.10/CustomPath?CustomSession=null' failed: Error during WebSocket handshake: Unexpected response code: 404
And the config in Caddyfile is:
route /CustomPath/* {
uri strip_prefix /CustomPath
reverse_proxy websocket:1000/websockethub {
header_up Sec-WebSocket-Protocol {>Sec-WebSocket-Protocol}
What can I do to make websocket to work please
Caddy v2 does not support paths in the proxy address. Instead, add a rewrite rule which will add the path prefix you need before proxying.
Also, it’s unnecessary to do that header_up because in v2 all headers are forwarded by default.
You may also use the new handle_path directive (added in v2.1) instead of route which will let you remove the uri strip_prefix line.
handle_path /CustomPath/* {
rewrite * /websockethub{path}
Unfortunately I’m still getting that 404 in the console.
My old config, used with Caddy .9 was:
proxy /CustomPath http://websocket:5100/websockethub {
without /CustomPath
websocket
header_upstream Sec-WebSocket-Protocol {>Sec-WebSocket-Protocol}
What’s your full Caddyfile at this point? We need the full Caddyfile to make sure that you don’t have something else conflicting with it.
Can you see access logs on your websocket server to see what path it’s seeing as a 404? We’ll need more information to help debug this further.
You can also enable the debug global option which will log more details about the reverse_proxy requests.
It is something like this:
https://
tls internal {
on_demand
log
header /securepath {
Access-Control-Allow-Origin *
-Server
@xlsx {
path *.xlsx
header @xlsx Content-Type application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
header / -Server ""
header / -x-powered-by ""
header / {
X-Frame-Options "SAMEORIGIN"
route /PathNew/* {
uri strip_prefix /PathNew
reverse_proxy pathweb:1123
(I have more routes)
Thanks
Did you enable the debug global option? What do you see in your logs? There’s still not enough info here.
I enabled it like:
output file /var/log/caddy_test.log
level DEBUG
but I don’t see something logged there
An error log below maybe will help with something
"logger":"http.log.access","msg":"handled request","request":{"method":"GET","uri":"/CustomPath?Session=null","proto":"HTTP/1.1","remote_addr":"10.0.0.2:60434","host":"10.10.10.100","headers":{"Connection":["Upgrade"],"Cache-Control":["no-cache"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.116 Safari/537.36"],"Upgrade":["websocket"],"Cookie":["Session=b35ead60-d805-4bd2-87af-abf0008d4a81; SessionInactivityTimeout=0; G4SLogoutUrl=%2F%2F10.10.10.100%2F%2FLogin"],"Sec-Websocket-Extensions":["permessage-deflate; client_max_window_bits"],"Pragma":["no-cache"],"Origin":["https://10.10.10.100"],"Sec-Websocket-Version":["13"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-GB,en-US;q=0.9,en;q=0.8"],"Sec-Websocket-Key":["laxQEQ16zQCszDTzo7zdmQ=="]},"tls":{"resumed":true,"version":772,"ciphersuite":4865,"proto":"","proto_mutual":true,"server_name":""}},"common_log":"10.0.0.2 - - [06/Jul/2020:09:16:05 +0000] \"GET /CustomPath?Session=null HTTP/1.1\" 404 0","duration":0.000092119,"size":0,"status":404,"resp_headers":{"Server":["Caddy"]}}
Thank you
matt
(Matt Holt)
8
That enables access logging only, which doesn’t currently have any debug emissions.
You will need to use the debug global option to enable debug logging.
The problem has been fixed with:
rewrite * /websockethub?{query}
Thank you
matt
(Matt Holt)
10
Awesome, glad you figured it out! Thanks for sharing the solution.
