Website is offline - maintenance page - exclude myself
newest
VPS
Ubuntu 20.4 LTS
Paste command here.
# GLOBAL
        # Optional email key for lets encrypt
        # Optional staging lets encrypt for testing.
        servers {
                timeouts {
                        read_body 10s
                        read_header 10s
                        write 10s
                        idle 2m
                max_header_size 16384
# SNIPPETS
(mustheaders) {
                Strict-Transport-Security "max-age=31536000; includesubdomains; preload"
                X-Frame-Options "SAMEORIGIN"
                Referrer-Policy "same-origin"
                X-Xss-Protection "1; mode=block"
                Feature-Policy "accelerometer 'none'; autoplay 'none'; camera 'none'; encrypted-media 'none'; fullscreen 'self'; geolocation 'none'; gyroscope 'none'; magnetometer 'none'; microphone 'none'; midi 'none'; payment 'none'; picture-in-picture *; sync-xhr 'none'; usb 'none'"
                Expect-CT "max-age=604800"
                -Server
(onlinewebsite) {
        @offline expression `"{args.0}" == "no"`
        handle @offline {
                header X-Robots-Tag "noindex, nofollow, noarchive, nosnippet, notranslate, noimageindex"
                header Cache-Control "no-cache, no-store, must-revalidate"
                @public_networks not remote_ip 11.111.11.11 #EXAMPLE MY IP
                rewrite @public_networks index.html
                root * /home/maintenance.site
        header X-Robots-Tag "noarchive, notranslate"
(compression) {
        encode zstd gzip
(caching) {
        @static {
                file
                path *.css *.js *.ico *.gif *.jpg *.jpeg *.png *.svg *.woff
        handle @static {
                header ?Cache-Control "public, max-age=5184000, must-revalidate"
                header ?Cache-Control "no-cache, no-store, must-revalidate"
(robots) {
        header /robots.txt {
                User-agent:*
                Allow: /
                User-agent: *
                Disallow: /*.php$
                Disallow: /*.inc$
                Disallow: /*.zip$
                Disallow: /*.pdf$
                Sitemap: https://{http.request.host.labels.1}.{http.request.host.labels.0}/sitemap.xml
        respond /robots.txt 200
(proxy) {
        header_up X-Forwarded-For {remote}
        header_up X-Real-IP {remote}
        header_down X-Powered-By "the Holy Spirit"
        header_down Server "CERN httpd"
(logs) {
                output file /var/log/caddy/caddy.log
(php) {
        php_fastcgi / unix//run/php/php7.4-fpm.sock
# WEBSITES
website.com {
        import mustheaders
        import caching
        import onlinewebsite yes
        respond /healthcheck 200
        reverse_proxy 127.0.0.1:2050 {
                import proxy
        import logs
Please check the “onlinewebsite” snippet. I use it to make my website offline for maintenance. I wanted to redirect users to maintenance page except me. However “not remote_ip” doesn’t work and I also see the maintenance page.
How to exclude myself from the maintenance rewrite?
no errors
no clue what to do next
Which version, exactly? “Newest” is not specific, and may not be true. Please run the caddy version command to find the version.
Remove this line. Caddy already sends this header to upstreams by default, correctly.
I think you want to use the remote_ip matcher with your offline matcher rather than inside of that handle.
Check your logs to make sure your actual IP address is seen by Caddy in the remote_addr field. Maybe some TCP layer proxy in front of Caddy is causing the IP address to get changed.
Who can show the proper code?
What did you try?
the snippet as mentioned above
(onlinewebsite) {
        handle @offline {
But you didn’t try to change your config as I suggested.
Try that.
Do you mean I should get rid of “handle” word and leave everything else?
No. Your config does not make sense and won’t work. Analyze it first to understand why is your config not working as you expect. Let’s first remove the noise:
(onlinewebsite) {
        handle @offline {
website.com {
Now let’s include the snippet in-line instead of being a snippet (replacing args in the process):
website.com {
        @offline expression `"yes" == "no"`
        handle @offline {
Will the content if handle ever be applied? What is the actual condition you want to match for the directives to be applied?
website.com {
“yes” means I import onlinewebsite snippet with "header X-Robots-Tag “noarchive, notranslate” only.
if I there is “import onlinewebsite no”, it should load different - maintenance site. And it does. It works almost fine, however it doesn’t ignore my IP, so I have no access to the site too via browser.
Again, I want to make my IP ignored, so I can see the main website instead of maintenance.site.
