I have a Node.js application using LemonSqueezy webhooks that works perfectly in local environment and other hosting providers like fly.io. However, when deployed on my VPS using Caddy as reverse proxy with Cloudflare, the webhooks fail with a signature verification error. The error persists even when Cloudflare is paused, suggesting an issue with how the request body is being handled through Caddy. Error: ERR_CRYPTO_TIMING_SAFE_EQUAL_LENGTH occurs during webhook signature verification.
I don’t exactly know if this is a Caddy problem or not but weirdly enough even after extensive logging in my code none of them show up in my docker logs, and that is why i am here asking for your help.
I will be honest and say that this is my first time hosting a full web app on a VPS with Caddy and Cloudflare especially a one with payment integration so if i have made any mistake please be kind and help me through it, also ignore any minor issues in my post as this is my first time posting in the community here.
text
Webhook error: RangeError: Input buffers must have the same byte length
at _paymentsWebhookfn (/app/src/payment/lemonSqueezy/webhook.ts:27:17)
at <anonymous> (/app/build/server/src/routes/apis/index.ts:39:14)
at <anonymous> (/app/out/sdk/server/utils.ts:26:11)
at Layer.handle [as handle_request] (/app/build/server/node_modules/express/lib/router/layer.js:95:5)
at next (/app/build/server/node_modules/express/lib/router/route.js:149:13)
at /app/build/server/node_modules/body-parser/lib/read.js:137:5
bash
Caddy v2.7.6
- Ubuntu 22.04 LTS
- Docker for containerization
- Caddy as reverse proxy
- Cloudflare for DNS and SSL
bash
docker run -d \
--name myapp \
--env-file .env.production \
-p 127.0.0.1:3001:3001 \
--network app-vps-network \
myapp
N/A - Using Docker directly
auto_https off
myapp.com, www.myapp.com {
root * /home/username/webdevelopment/myapp/client
try_files {path} /index.html
tls /home/username/webdevelopment/myapp/cloudflare-origin-cert.pem /home/username/webdevelopment/myapp/cloudflare-origin-key.pem
output file /var/log/caddy/myapp_access.log
format json
api.myapp.com {
@webhook {
path /payments-webhook
path /operations/*
handle @webhook {
header Content-Type application/json
header -Content-Encoding
reverse_proxy localhost:3001 {
header_up Content-Type application/json
header_up X-Signature {http.request.header.X-Signature}
output file /var/log/caddy/api_access.log
format json
level DEBUG
bot.myapp.com {
reverse_proxy localhost:3000
output file /var/log/caddy/bot_access.log
format json
- LemonSqueezy Webhook Documentation: API Docs: The Webhook Object • Lemon Squeezy
