Webcam subdirectory only works on LAN
I have Caddy setup to host some websites locally. If I type https://mainsail.harding.trev.red it works and loads correctly. Mainsail is an app to interface with a 3D Printer. So, I have a webcam that I can use to look at my print to make sure nothing has failed so far. That works when I am on LAN. I connected my network/dns through a VPN (Tailscale) and I can still access Mainsail but the cam doesn’t work. I assume I need to somehow serve the webcam. So, I found that the actual URL for the webcam is https://mainsail.harding.trev.red/webcam/webrtc and I tried accessing that directly. I can confirm that when I am on LAN, that shows the webcam, but if I am going through the VPN, that URL loads nothing.
I assumed that it was a VPN issue, but the fact that it loads the rest of the page means that DNS is working, communicating with LAN devices (DNS, Caddy, and the Mainsail Raspberry Pi), and caddy since it’s accessible through https with a cert. So, my assumption is that I just need to serve /webcam/webrtc through Caddy. I looked at the documentation and it seemed to be more about files and the keyword was rewrite. So, I don’t think that would really apply here. Any advice would be greatly appreciated!
There are no logs that have anything to do with mainsail.
OS: Proxmox VE 7.4-17 x86_64
Host: 10MUS35500 ThinkCentre M910q
Kernel: 5.15.131-1-pve
Docker version 24.0.7, build afdd53b
Docker Compose version v2.21.0
docker compose up --force-recreate --build -d
DockerFile
FROM caddy:2.7-builder AS builder
RUN xcaddy build --with github.com/caddy-dns/cloudflare@latest
FROM caddy:2.7
version: "3"
    build:
      context: .
      dockerfile: Dockerfile
    restart: always
      - 443:443
      - 2019:2019
      - ./config:/config
      - ./data:/data
      - ./logs/:/logs/
      - ./sites/:/etc/caddy/sites/
      - web
  web:
    external: true
trev.red, *.trev.red, *.harding.trev.red {
                dns cloudflare CLOUDFLARE-API-KEY
        respond "go away!"
import sites/*.caddy
sites/3d-printer.caddy
mainsail.harding.trev.red {
        reverse_proxy http://192.168.5.26
I figured out that this was a networking issue. I had the raspberry pi running Klipper on my IoT VLAN but my VPN only gave access to my default VLAN.
