Web socket proxy doesn't work as expected
I’ve been running nginx on another machine but moved everything away, expect a phoenix web app. The proxy works unless I try to do something with the websocket
I try to convert the following nginx config:
upstream my_app {
    server 127.0.0.1:4000;
map $http_upgrade $connection_upgrade {
    default upgrade;
    '' close;
 location / {
    try_files $uri @proxy;
  location @proxy {
    include proxy_params;
    proxy_redirect off;
    proxy_pass http://my_app;
    # The following two headers need to be set in order
    # to keep the websocket connection open. Otherwise you'll see
    # HTTP 400's being returned from websocket connections.
    proxy_set_header Connection $connection_upgrade;
  location /live {
    proxy_http_version 1.1;
    proxy_set_header Origin '';
Did anyone encounter the same problem or know how to solve this?
My current config looks like this
demo.chocolatecoding.com {
        @websockets {
                header_regexp Connection Upgrade
                header Upgrade websocket
        handle /live* {
                header X-Real-IP {remote_host}
                header X-Forwarded-For {proxy_add_x_forwarded_for}
                header Host {http_host}
                header Upgrade {http_upgrade}
                header Connection {upgrade}
                reverse_proxy @websockets casamento:4000
        reverse_proxy casamento:4000
caddy  | {"level":"debug","ts":1680560986.132457,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"casamento:4000","duration":0.001130571,"request":{"remote_ip":"2001:678:aac:200::1","remote_port":"40664","proto":"HTTP/1.1","method":"GET","host":"demo.chocolatecoding.com","uri":"/live/websocket?_csrf_token=AxMAaGsKOhJ_JntXeUUSe1EiCR4CdTIknUvZ1sqFFlM97hpJ2WpyT3yt&_track_static%5B0%5D=https%3A%2F%2Fdemo.chocolatecoding.com%2Fassets%2Fapp-68adc0614a4d55f8cf4a90bfa2517b01.css%3Fvsn%3Dd&_track_static%5B1%5D=https%3A%2F%2Fdemo.chocolatecoding.com%2Fassets%2Fapp-b3cb35211d10aa0c5fdd7e45ca66e397.js%3Fvsn%3Dd&_mounts=0&vsn=2.0.0","headers":{"Cookie":[],"Sec-Websocket-Extensions":["permessage-deflate; client_max_window_bits"],"X-Forwarded-For":["2001:678:aac:200::1"],"X-Forwarded-Proto":["https"],"Sec-Websocket-Version":["13"],"Accept-Encoding":["gzip, deflate, br"],"Connection":["Upgrade"],"Upgrade":["websocket"],"Sec-Websocket-Key":["v14cSj8Zv2O5VEihI32RZA=="],"Accept-Language":["en-US,en;q=0.9"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36"],"Pragma":["no-cache"],"X-Forwarded-Host":["demo.chocolatecoding.com"],"Origin":["https://demo.chocolatecoding.com"],"Cache-Control":["no-cache"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"demo.chocolatecoding.com"}},"headers":{"Date":["Mon, 03 Apr 2023 22:29:46 GMT"],"Server":["Cowboy"],"Cache-Control":["max-age=0, private, must-revalidate"],"Content-Length":["0"]},"status":403}
v2.6.4
Docker via docker compose
docker
Remove all this. It doesn’t do anything useful.
Caddy proxies WebSockets automatically, there’s nothing special you need to do with headers.
It should be sufficient to just do reverse_proxy casamento:4000
