I wish to use the cert generated by Caddy for my website also for my postgres ssl connection. Is this OK? According to postgres, the user running postgres must be the owner of the file. But Caddy is the owner, and if I change it I think Caddy will stop functioning correcting for this url? Please let me know what should I do?
2025-03-26 01:34:20.549 UTC [19132] FATAL: private key file "/var/lib/caddy/.local/share/caddy/certificates/acme-v02.api.letsencrypt.org-directory/site-name/site-name.key" must be owned by the database user or root
v2.9.1
Ubuntu
It’s definitely okay. Are you planning on using the Let’s Encrypt certificates? If yes, I’d recommend against that. For database connectivity, I’d put my root of trust in my own CA, vhich Caddy manages. You can have Caddy generate the root and leaf certificate for the various use cases.
In regards to the file ownership, if the sole user of the certificate is PostgreSQL, are there risks in running Caddy with the same user as Postgres? I can’t think of any, especially if you’re using Caddy’s internal PKI, so the ACME challenges aren’t needed. Another solution is to rely on Caddy events system and use the exec event handler no copy the certificate elsewhere and chown it to a different user. You might need to edit the sudoer file to allow Caddy user to chmod files.
One possible solution could be creating a cron job script to check the certificate in Caddy’s certificate folder and compare it with the one used by Postgres.
The script would compare their hashes, and if they differ, it would copy the new certificate from Caddy’s folder to Postgres’ folder, update the key/certificate file ownership, and reload the Postgres service.
Thanks for the response Mohammed. So you think it’s better to generate my own cert (is this what you mean by “my own CA”)? Would this present any connectivity issues compared to going with an official CA like LetsEncrypt?
In regards to the exec handler, you mean it allows to copy the cert every time it’s updated by Caddy?
I believe @Mohammed90 means having Caddy handle it with a specific configuration, which means adjusting PKI. This is one solution for file ownership by utilizing a shared user for both PostgreSQL and Caddy.
This is the second option he specified. Yeah, it looks like it is capable of reloading a configuration for a daemon when it detects a certificate change, or in other words, you can configure it to copy the certificate somewhere and chown it to the PostgreSQL user. Doing so would likely need Caddy to have elevated privileges, so you would probably need to add the Caddy user to the sudoer file.
It looks like @timelordx’s solution is a different way of doing what the caddy-events-exec would accomplish. Either way will work.
Quick question. If I did this, I think there is a possibility it could cause downtime. I.e. there could be some lag between the new cert being issued and the cron running. Or does Caddy renew certs some time before the current one expires? In such a case a daily cron would work.
Yes, I don’t remember exactly how many days in advance it renews, but it’s well ahead of time, so a daily cron job should work just fine. That’s how it’s been running on my Synology for quite some time now, renewing the wildcard certificate I use there.
I’m a little confused regarding the root, leaf and CA certificates. Is this something I have to manage if I follow your cron job suggestion? Say for example if I want to connect to the db from my desktop.
Caddy provides everything - both the key and the full chain. If you need to separate the certificate from the chain, you can easily do so. One way to do it is shown here:
If you’re using Caddy to obtain a properly trusted certificate and have configured Postgres to present both the certificate and the chain correctly, your desktop clients should have no issues connecting to the database. The trusted root CAs that Caddy uses to issue third-party certificates are already included in the trusted stores of all modern OSes and browsers.
It’s up to you. Client-side certificate authentication is generally more secure than just a login and password, but unless you’re prepared to run your own Certificate Authority and issue certificates for all your clients, I’d steer clear of it. It really comes down to how much security you need. In most cases, SSL/TLS encryption combined with login and password authentication should be sufficient.
