v2.3
caddy run --config=caddy.json
Ubuntu 20.04
"apps": {
"tls":{
"automation":{
"policies":[{
"issuer":{
"module": "acme",
"challenges": {
"dns": {
"provider": {
"name": "cloudflare",
"api_token": "CLOUDFLARE_API_TOKEN"
"http": {
"servers": {
"example": {
"listen": [":443"],
"routes": [
"match": [{"host": [
"app.example.net"
"handle": [
"handler": "reverse_proxy",
"upstreams": [
{"dial":"x.x.x.x:4000"}]
"*.example.net",
"example1.co.li",
"example2.co.li",
"example3.com"
"handle": [
"upstreams": [
{"dial":"x.x.x.x:5000"}
I want to server my clients domains from caddy, some of them are using subdomains and some of them are using white label domains.
Subdomains are working fine by adding wildcard record i.e. *.example.net .
But the problem is, right now I am adding each white label domain in my config file to make it work. Like this -
"*.example.net",
"example1.co.li",
"example2.co.li",
"example3.com"
As per your documentation, it is possible to configure caddy to serve all the domain names you do not know and that can’t be configured ahead of time.
But I was enable to find how to do that.
When I try to access the new white label domain example4.co.li then I got “Secure Connection Failed” error.
I tried to add “*” along with all the listed domains to support all the upcoming clients white label domains but it didn’t work.
