VueJS with JSON
I am trying to get the VueRouter redirections to work eg:. https:///cs2darchive.com/clients
Now I understand somehow I have to redirect each routes to index.html, but I am unsure how to do that with JSON, I only found Caddyfile examples, but those are a bit different huh.
HTTP 404 errors whenever I press F5 on any of the VueRouter pages.
v2.8.4
Using Caddy's repository and via apt install caddy
Ubuntu 24.04 Server on Aarch64 Raspi5 via systemd
sudo caddy run --config global-caddy.json
    "apps": {
        "http": {
            "servers": {
                "default": {
                    "listen": [
                        ":80"
                    "routes": [
                            "handle": [
                                    "handler": "file_server",
                                    "root": "/path/to/default/root"
                "https": {
                    "listen": [
                        ":443"
                    "routes": [
                            "handle": [
                                    "root": "/home/marcell/PagerCast/"
                            "match": [
                                    "host": [
                                        "pager.brohosting.eu"
                            "handle": [
                            "match": [
                                    "host": [
                                        "asf.raspberry.local"
                            "handle": [
                            "match": [
                                    "host": [
                                        "pagercast.com",
                                        "api.pagercast.com",
                                        "www.pagercast.com"
                            "handle": [
                                    "root": "/home/marcell/_domains/cs2darchive.com/dist"
                            "match": [
                                    "host": [
                                        "cs2darchive.com",
                                        "www.cs2darchive.com"
                                    "not": [
                                            "path": [
                                                "/api/*"
                            "handle": [
                                    "handler": "reverse_proxy",
                                    "upstreams": [
                                            "dial": "localhost:3415"
                            "match": [
                                    "host": [
                                        "cs2darchive.com",
                                    "path": [
                                        "/api/*"
                            "handle": [
                                    "root": "/home/marcell/_domains/verify.gtavc.cc/dist"
                            "match": [
                                    "host": [
                                        "verify.gtavc.cc"
                                    "not": [
                                            "path": [
                                                "/api/v1/*"
                            "handle": [
                                    "upstreams": [
                                            "dial": "localhost:3000"
                            "match": [
                                    "host": [
                                        "verify.gtavc.cc"
                                    "path": [
                                        "/api/v1/*"
                    "tls_connection_policies": [
                            "certificate_selection": {
                                "any_tag": [
                                    "default"
        "tls": {
            "certificates": {
                "load_files": [
                        "certificate": "/home/marcell/PagerCast/certs/cert.pem",
                        "key": "/home/marcell/PagerCast/certs/privkey.pem",
                        "tags": [
                            "default"
Howdy @sqpp, welcome to the Caddy community.
Unfortunately I’m not particularly great with JSON myself, but I have to ask, have you seen the caddy adapt command?
With it you could take any of the examples you’ve seen and spit out the JSON version. Since I’m a Caddyfile user, in your shoes I’d look at configuring a setup with try_files (Caddyfile directive) — Caddy Documentation and then adapt-ing it as necessary.
Thanks fro the welcome! Nice meeting you!
I am thinking to ditch JSON at this point as I am always getting into roadblocks everytime, even with the environmental variables.
I tried to use try_files but I got into a redirection loop, but I am very unfamiliar with Caddy file or even how Caddy handles these rewrites.
Redirect loop from a request router… Can’t say that’s a common issue I’ve seen, unfortunately. Is there some nuance for VueRouter that might mistakenly redirect you off the page?
If you check out the try_files expanded form you can see what it does. It uses a file matcher to try find a file and then uses rewrite (Caddyfile directive) — Caddy Documentation to serve it. The first example on the page demonstrates its use for a router entrypoint.
Single page applications are pretty much exactly what this kind of directive is for. The behaviour is included by default in php_fastcgi (Caddyfile directive) — Caddy Documentation, for example.
Not sure about the try_files directive, I have seen examples in Caddyfile, but not with JSON.
All I know that this .htaccess worked perfectly with OLS before, so the issue is unlikely the router itself.
<IfModule mod_rewrite.c>
  RewriteEngine On
  RewriteBase /
  # Handle requests for existing files or directories
  RewriteCond %{REQUEST_FILENAME} -f [OR]
  RewriteCond %{REQUEST_FILENAME} -d
  RewriteRule ^ - [L]
  # Handle all other requests
  RewriteRule ^ index.html [L]
</IfModule>
Well, lets look at what the .htaccess file does:
  1. RewriteCond %{REQUEST_FILENAME} -f [OR]
    This checks if the request is for a real file on disk.
  2. RewriteCond %{REQUEST_FILENAME} -d
    This checks if the request is for a directory on disk.
  3. RewriteRule ^ - [L]
    If either condition above is true, don’t rewrite (- means no substitition) and stop evaluating ([L] means don’t process any more rules).
  4. RewriteRule ^ index.html [L]
    This part rewrites all requests to the webroot index.html if we didn’t already find a file or directory and no-op the rewrite.
So basically - look for a file. Look for a directory. If neither exist, fall back to the webroot index.
Functionally, all of that is identical to:
try_files {path} {path}/ /index.html
Which checks each in sequence and goes with the first match it can find:
  1. {path} checks for a file on disk and proceeds with it if it exists.
  2. {path}/ checks for a directory on disk and proceeds with it if it exists.
  3. /index.html is the last option and therefore a fallback if neither of the previous checks were successful.
There’s nothing here which causes any redirects, all rewriting is internal and hidden from the client.
I had to make a ton of changes, also switching from JSON to Caddyfile as its way simpler since 85% of the resources on the internet are Caddyfile, but in the end I was able to get it working… :slight_smile:
All websites rocking now!
Thank you!
