): V2.3.0
sudo systemctl start caddy
ubuntu 18.04
root * /var/www/html
handle_path /administracion/ * {
root * /var/www/html/smiled-front/dist
handle_path /admin/ *:443 {
reverse_proxy 127.0.0.1:8000 {
header_up X-Real-IP {http.request.remote}
header_up X-Forwarded-For {http.request.remote}
header_up X-Forwarded-Proto {http.request.scheme}
I have a Vuejs app running at /administracion route, with a login form, so after enter credentials and submit form I spect a call to 127.0.0.1:8000/admin/auth/login (where my fastapi API runs on gunicorn).
CORS policy error.
5. What I already tried: change the port where API runs
It looks like it’s redirecting you from http://127.0.0.1
to http://127.0.0.1:8000
. Make sure the redirect uses the right port.
This isn’t valid syntax. handle_path
takes a path prefix as an option. For example handle_path /admin/* {
or handle_path /admin* {
Also, it seems like you have handle_path
outside your :80
site. It needs to be inside that site block. See the structure:
Also please run caddy fmt
on your config to clean up the syntax, it’s quite messy.
Remove all these. They’re not necessary, and in some cases may even be harmful.
Ok , I did some modification to my Caddyfile:
example.com {
handle_path /administracion/* {
But still getting the same error…really frustrating.
If you don’t share logs or curl -v
output of what you’re seeing, then I can’t help.
Help me help you.
root@localhost:/var/www/html/smiled-front# curl -v 127.0.0.1:8000
* Rebuilt URL to: 127.0.0.1:8000/
* Trying 127.0.0.1...
* TCP_NODELAY set
* Connected to 127.0.0.1 (127.0.0.1) port 8000 (#0)
GET / HTTP/1.1
Host: 127.0.0.1:8000
User-Agent: curl/7.58.0
Accept: /
HTTP/1.1 404 Not Found
date: Fri, 07 May 2021 20:09:13 GMT
server: uvicorn
content-length: 22
content-type: application/json
* Connection #0 to host 127.0.0.1 left intact
That’s what I’m seeing…please tell me if is what you expect.
Your request isn’t hitting Caddy, it’s hitting your uvicorn server. Caddy is listening on port 80, not 8000.
Ok, I understand…but I don’t know how to solve it…should I create something like example.com:8000 ??
Your goals are not clear here. I can’t answer that question without more information.
I figured out !! now it’s working…I have the .env variable inside my vue app pointing to localhost instead my domain…thank you !! you were big help!!
system
(system)
closed
June 6, 2021, 7:34pm
#10
