Virtual hosts outside https:// catch all
1. Caddy version 2.0.0:
Caddy is running as a systemd service.
Ubuntu 18.04,caddy installed from apt and running as a service
http:// {
 redir https://{host}{uri}
https:// {
  on_demand
 reverse_proxy 127.0.0.1:8084
example.com {
 reverse_proxy 127.0.0.1:8080
www.example.com {
example.com or www.example go to 127.0.0.1:8084 not 127.0.0.1:8080.EDIT:Alright, while writing this post i found that it worked when i left an empty space after the domain and before the bracket.Otherwise it would throw me to :8084.Is an empty space required or is this unexpected behaviour?
Using
www.example.com , example.com {
The sites example.com work but all other domains point to :8080.So i have to make a seperate for www and non-www.Is this intended behaviour?
Thanks!
Does this work?
http:// {
https:// {
        on_demand
example.com, www.example.com {
The adapted JSON looks correct to me. (i.e. the output of caddy adapt)
Yes, the space is necessary because otherwise the { would be parsed as being part of the domain.
It’s invalid to have a space before the comma.
Hi Francis,
that seems to have been the problem.Silly me!
Thanks!
