Very weird issue regarding on demand TLS and unconsistent behavior
I want to use caddy for its reverse proxy and TLS issuing capabilites. Specifically the on demand tls feature. It is used for issuing certificates with the local CA, no public access. The server offers services reachable via its IPs, hostnames and also .local domains that are published via mDNS in the network. My config creates the following inconsistent behavior:
Curl to hostname
curl -k -v -L "http://server01"
*   Trying 192.168.60.38:80...
* Connected to server01 (192.168.60.38) port 80 (#0)
> GET / HTTP/1.1
> Host: server01
> User-Agent: curl/7.81.0
< HTTP/1.1 200 OK
< Alt-Svc: h3=":443"; ma=2592000
< Content-Type: text/html
< Server: Caddy
< Date: Mon, 28 Apr 2025 23:17:20 GMT
< Content-Length: 49
* Connection #0 to host server left intact
<html><body><h1>Great success!</h1></body></html>
  1. The redirect from HTTP to HTTPS does not work
  2. I get the response body
Curl to *.local domain
curl -k -v -L "http://server01.local"
* Connected to server01.local (192.168.60.38) port 80 (#0)
> GET / HTTP/1.1
> Host: server01.local
< Connection: close
< Location: https://server01.local/
< Server: Caddy
< Date: Mon, 28 Apr 2025 23:19:36 GMT
< Content-Length: 0
* Closing connection 0
* Issue another request to this URL: 'https://server01.local/'
*   Trying 192.168.60.38:443...
* Connected to server01.local (192.168.60.38) port 443 (#1)
* ALPN, offering h2
* ALPN, offering http/1.1
* Using Stream ID: 1 (easy handle 0x62a3f1bf99f0)
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
> GET / HTTP/2
> user-agent: curl/7.81.0
> accept: */*
* TLSv1.2 (IN), TLS header, Supplemental data (23):
< HTTP/2 200
< server: Caddy
< content-length: 0
< date: Mon, 28 Apr 2025 23:19:36 GMT
* Connection #1 to host server01.local left intact
  1. I get a redirect from HTTP to HTTPS as it should be
  2. I get no response body
Curl to IP
curl -k -v -L "http://192.168.60.38" → Same output as curl to *.local
Here is the log for first a request to a IP, then to the *.local domain. You will laugh, but for just the hostname I don’t get log output.
{"level":"info","ts":1745883674.2854295,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1745883674.2857394,"logger":"http.log","msg":"server running","name":"main","protocols":["h1","h2","h3"]}
{"level":"info","ts":1745883674.2857552,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*"]}
{"level":"warn","ts":1745883674.2857654,"logger":"tls","msg":"YOUR SERVER MAY BE VULNERABLE TO ABUSE: on-demand TLS is enabled, but no protections are in place","docs":"https://caddyserver.com/docs/automatic-https#on-demand-tls"}
{"level":"warn","ts":1745883674.2864292,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1745883674.2906094,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/root/.local/share/caddy","instance":"a4f5efb8-93e8-4340-bde9-cea6d52c68eb","try_again":1745970074.2906065,"try_again_in":86399.999999566}
{"level":"info","ts":1745883674.2907023,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"error","ts":1745883674.2954905,"logger":"pki.ca.local","msg":"failed to install root certificate","error":"failed to execute sudo: exit status 1","certificate_file":"storage:pki/authorities/local/root.crt"}
{"level":"debug","ts":1745883674.2955394,"logger":"events","msg":"event","name":"started","id":"9e5b14b5-3b44-4e70-b6ce-3cabce46b5d3","origin":"","data":null}
{"level":"info","ts":1745883674.2956579,"msg":"autosaved config (load with --resume flag)","file":"/root/.config/caddy/autosave.json"}
{"level":"debug","ts":1745883683.069651,"logger":"events","msg":"event","name":"tls_get_certificate","id":"7ed40528-4925-4353-a036-ad539f428955","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"192.168.60.68","Port":36620,"Zone":""},"LocalAddr":{"IP":"192.168.60.38","Port":443,"Zone":""}}}}
{"level":"debug","ts":1745883683.0698292,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"192.168.60.38"}
{"level":"debug","ts":1745883683.0698707,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","remote_ip":"192.168.60.68","remote_port":"36620","sni":""}
{"level":"debug","ts":1745883683.070528,"logger":"tls.cache","msg":"added certificate to cache","subjects":["192.168.60.38"],"expiration":1745924011,"managed":true,"issuer_key":"local","hash":"0863b520452fa56ba4d025178fce814340eb32891427aab6cfbc1e5e790f555f","cache_size":1,"cache_capacity":10000}
{"level":"debug","ts":1745883683.070587,"logger":"events","msg":"event","name":"cached_managed_cert","id":"3ff6716e-f3d7-45b4-bd11-19e8d54bda8f","origin":"tls","data":{"sans":["192.168.60.38"]}}
{"level":"debug","ts":1745883683.0706265,"logger":"tls.handshake","msg":"loaded certificate from storage","remote_ip":"192.168.60.68","remote_port":"36620","subjects":["192.168.60.38"],"managed":true,"expiration":1745924011,"hash":"0863b520452fa56ba4d025178fce814340eb32891427aab6cfbc1e5e790f555f"}
{"level":"debug","ts":1745883691.9273942,"logger":"events","msg":"event","name":"tls_get_certificate","id":"a43af01b-7755-467d-91e4-6d4d2719a57c","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"server01.local","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"192.168.60.68","Port":48458,"Zone":""},"LocalAddr":{"IP":"192.168.60.38","Port":443,"Zone":""}}}}
{"level":"debug","ts":1745883691.9275274,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"server01.local"}
{"level":"debug","ts":1745883691.9275544,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.local"}
{"level":"debug","ts":1745883691.9275672,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*"}
{"level":"debug","ts":1745883691.927588,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","remote_ip":"192.168.60.68","remote_port":"48458","sni":"server01.local"}
{"level":"debug","ts":1745883691.9283504,"logger":"tls.cache","msg":"added certificate to cache","subjects":["server01.local"],"expiration":1745924028,"managed":true,"issuer_key":"local","hash":"5e07af611f7cc108fd6ba2aae2ec52e5ca4c180ba6dffe60c995065949cee2b3","cache_size":2,"cache_capacity":10000}
{"level":"debug","ts":1745883691.9284291,"logger":"events","msg":"event","name":"cached_managed_cert","id":"997358c9-2290-44a7-88dc-cf6caeb0c4fb","origin":"tls","data":{"sans":["server01.local"]}}
{"level":"debug","ts":1745883691.928465,"logger":"tls.handshake","msg":"loaded certificate from storage","remote_ip":"192.168.60.68","remote_port":"48458","subjects":["server01.local"],"managed":true,"expiration":1745924028,"hash":"5e07af611f7cc108fd6ba2aae2ec52e5ca4c180ba6dffe60c995065949cee2b3"}
caddy --version
sudo apt install caddy
Ubuntu 24.04.2
n.A., I use the systemd service
Type=notify
User=root
Group=root
ExecStart=/usr/bin/caddy run --environ --resume
ExecReload=/usr/bin/caddy run --resume
    "admin": {
        "disabled": false
    "apps": {
        "tls": {
            "automation": {
                "policies": [
                        "issuers": [
                                "module": "internal",
                                "sign_with_root": false
                        "on_demand": true
        "http": {
            "servers": {
                "main": {
                    "listen": [
                        ":80",
                        ":443"
                    "routes": [
                            "match": [
                                    "host": [
                            "handle": [
                                    "handler": "static_response",
                                    "body": "<html><body><h1>Great success!</h1></body></html>",
                                    "headers": {
                                        "Content-Type": [
                                            "text/html"
n.A.
"host": ["*"] will only match single-label domains like localhost, not server01.local. You’d need *.* for that, or *.local, etc. See the docs for the host matcher:
