Vaultwarden on docker with caddy to reverse proxy
Caddy Version 2.4.6 (docker version)
Caddy is installed on Docker (docker-compose)
docker-compose version 1.25.3, build d4d1b42b
  • Caddy is installed on an VM running Docker.
  • VaultWarden is installed as a separate container in Docker too.
Paste command here.
version: '3'
  vaultwarden:
    image: vaultwarden/server:latest
    container_name: vaultwarden
    restart: always
      - WEBSOCKET_ENABLED=true  # Enable WebSocket notifications.
      - vw-data:/data
    image: caddy:2
    restart: always
      - ./ssl:/etc/ssl
      - caddy-config:/config
      - caddy-data:/data
      - caddy-logs:/logs
      - DOMAIN=https://vault.test.local
  vw-data:
  caddy-config:
  caddy-data:
  caddy-logs:
{vault.test.local}:443 {
  tls /etc/ssl/vault.cer /etc/ssl/vault.key}
  reverse_proxy /notifications/hub vaultwarden:3012
  reverse_proxy vaultwarden:80
I can’t launch the Caddy container I have this error and I don’t understand why.
{"level":"info","ts":1644855254.3671026,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | run: Adapt configuration using caddyfile: subject is not eligible for certificate: '{vault.test.local}'
Cart exited with code 1
Remove the braces from the domain name. That’s not valid syntax.
Also remove the extra brace at the end of this line.
Try this:
vault.test.local {
Ok thanks for your help.
