V2: Unrecognized directive when import external Caddyfile
Output of caddy version:
v2.0.0-rc.2 h1:7NOaxYrsnQ5D3rcLGn2UnLZHLfBpgrfM/JNTLhjCJ1c=
18.04.1-Ubuntu
Just caddy start or caddy run in the folder where the main Caddyfile is.
c. My complete Caddyfile:
main Caddyfile:
http://
@mobile {
  header_regexp User-Agent Mobile|Android|BlackBerry
reverse_proxy @mobile localhost:8082
reverse_proxy localhost:8081
import /path/to/another/Caddyfile
another Caddyfile:
:2018 {
  file_server browse
Caddy won’t start, and with the following error.
adapting config using caddyfile: /path/to/another/Caddyfile:1: unrecognized directive: :2018
I’ve tried to modify the first line from :2018 to something like localhost:2018, neither of them worked.
And the result of caddy validate was fine.
Hi all.
I’ve found out why the error happened.
This was because I didn’t wrap up the http:// part in curly braces.
Glad you figured it out!
FYI, Caddy v2.0.0 stable was just released on Monday, you’re using an old version.
Thanks for your kindness!
