Hey,
When I try this
matcher notStatic {
not {
file {
try_files {path}
I get this: unrecognized directive: not
Is that how it should be?
Hey,
When I try this
matcher notStatic {
not {
file {
try_files {path}
Hi Wayne, can you open a new thread and put your full Caddyfile and Caddy version? Thanks!
Edit: Aha! I learned a new trick, apparently we can splice replies out into new topics. That’s cool…
Anyway, can you still post your full Caddyfile and exact Caddy version? (Lots of changes have happened lately.)
Considering the timing, Matt, might it be because of the latest Caddyfile changes on the v2 branch?
New syntax would likely look like this:
@notStatic {
not {
file {
try_files {path}
try_files @notStatic /something.txt
That said, the full Caddyfile would help. Maybe you nested this matcher inside another directive where it shouldn’t be?
This seems to work correctly - at least, it doesn’t complain about failures
I ended out not actually needing that behavior, though, but here’s my sample config that worked:
:2015 {
root * /tmp/blarpish
@notFun {
not {
file {
try_files {path}
reverse_proxy @notFun localhost:8000
Thanks for the update!
