V2: SSLlab test A+ rating
Hi there. Using v1 with the instruction in here: Anyone archived A+ rating on SSL Labs? i was getting the A+ rating. Now with V2 i got only A: from the test’s log the problem seems to be “Strict Transport Security (HSTS) Invalid Server provided more than one HSTS header”. Here’s my Caddyfile:
mydomain.com {
   reverse_proxy /* 192.168.1.2:443 {
         tls
         tls_insecure_skip_verify
any clue?
Your backend at 192.168.1.2:443 is probably also setting that header, and you’re setting it with your header directive, so there are two of them.
You are right. I’ve removed it and now i got A+. Is it possible to put this header directive under the reverse_proxy? I mean, this config works too just for the reverse proxy right?
mydomain.com {
      tls
No, you can see the syntax of the reverse_proxy directive in the docs: reverse_proxy (Caddyfile directive) — Caddy Documentation
