V2: Rewrite and try_files
v2.0.0-beta11 h1:NVHnPAdZPt6OUBMltUMe2DWVsyYRbeE6NxhCm3AjGT8=
systemd unit file
systemd
Same as Caddy reference.
d. My complete Caddyfile:
api.qa.example.com {
  reverse_proxy * {
    to localhost:4100
qa.example.com {
  try_files {path} /index.html
  file_server / {
    root /var/www/example/qa/static
This is what I’m trying to do:
My root dir has only two files:
logout.html
index.html
I want /logout.html to serve logout.html
I want every other path to serve index.html
Please DO NOT REDACT any information except passwords/keys.
I tried matchers. I tried rewrite with “r” and a regexp like /.*logout\.html/
Thanks for trying v2 while it’s still in beta!
What about your configuration doesn’t work? You left question 3 unfinished I think, and question 4 is blank…
(in the future, please don’t redact domain names - we have good reasons for that)
FWIW @atonse, this config works as expected:
localhost
root * /Users/matt/Desktop/atonse
try_files {path} index.html
The only two files in the atonse folder are index.html and logout.html.
That did it. Thanks for taking the time to reply. I wouldn’t have arrived at that combination in a million years at least by looking at the docs. Can I suggest adding this particular example to the docs?
That’s good, but… isn’t it the same as your config? I was trying to say that I couldn’t reproduce the problem. I’m glad my config works, but I would think they both should work, no?
The v2 Caddyfile isn’t yet documented (except some blurbs in that awful wiki page for now), which is why it was hard to find documentation for it. :slight_smile: Yeah, I’ll be writing up docs this and next week.
Oh! Sorry, I know what happened. (I’ve been sick so comprehending is a little slow lately.)
This:
file_server / {
means that the site root is only known to the file server.
This:
root /Users/matt/Desktop/atonse
sets the root folder for the whole site. The try_files directive needs to know the root of the site, otherwise it assumes current working directory.
Will definitely make that clear in the new docs, don’t worry.
Good point. Also I’m not entirely sure what the “*” in the first root arg actually does. Can you set multiple roots? Conceptually that goes against the word “root” though.
Also, conceptually, I had tried to add try_files to the file_server block (because I’m asking it to try files to serve, in a file server). And that failed too.
Some of it is just the words not fully jiving in my head.
I didn’t know you could just say “file_server” for the whole site and have root outside of it.
That’s a matcher token. You can read more here, for now: GitHub - caddyserver/caddy: Fast and extensible multi-platform HTTP/1-2-3 web server with automatic HTTPS
Although part of that is a bit outdated. Next week, matchers are changing a bit (improving).
Basically, a matcher token makes that directive selective to only requests which match the matcher.
A * is a wildcard matcher. It’s implicit and can usually be omitted entirely, except that the next argument also looks like a path matcher. A path matcher starts with / and is the most common kind of matcher, so it’s a special case in that it can be defined inline. Other matchers can take the form @matcher_name which are defined in their own block. This is helpful when matching on some property of the request other than the path.
In Caddy 2, you sure can. You can set a different root depending on the kind of request you get (like its path, or anything else about it). It still means “root of the site” or “file root” so it’s still in harmony with the word.
You can’t arbitrarily nest directives inside other ones, unless the directive is specially designed to have other directives within it.
Yeah, we’re not nginx … contexts aren’t as much of a thing in the Caddyfile. The Caddyfile is much simpler, but also about as powerful.
Funny, thanks for the explanations. I was aware of matchers and tried them but it always felt like overkill for what I was trying to do (essentially try_files).
I’ve been using Caddy since the beginning, especially for dev, and am still learning new things. Keep up the good work.
Thanks. Yeah, the Caddyfile needed some polish and now it’s getting it, so it’ll be as easy to use as in v1 but even more powerful and flexible. Tricky to strike that balance. I hope you like the improvements.
