Latest Docker version (v2.0.0)
Docker, on Debian Buster
docker-compose up
image: caddy:latest
- ../volumes/caddy/Caddyfile:/etc/caddy/Caddyfile
- ../volumes/caddy/config:/config
- ../volumes/caddy/data:/data
# php-fpm roots
- ../volumes/nextcloud/html:/php-fpm-root/nextcloud
Note the last line, where I am bind mounting the html root of nextcloud into Caddy. I do the same for the nextcloud container, but into /var/www/html/ instead of /php-fpm-root/nextcloud
# /etc/caddy/Caddyfile
# Global config
# Let's Encrypt email
email myemail@example.com
cloud.example.com {
root * /php-fpm-root/nextcloud/
php_fastcgi nextcloud:9000 {
transport fastcgi {
root /var/www/html/ # This doesn't work!
# enable HSTS
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
respond @forbidden 404
3. The problem Iâm having:
I have Caddy running in a Docker container, as well as nextcloud in a container. I have the nexctcloud html directory shared between the two containers, bind mounted at ../volumes/nextcloud/html. For the nextcloud container, this goes to /var/www/html/, whereas in the Caddy container it goes to /php-fpm-root/nextcloud/.
Back in Caddy V1, as far as I can tell you were able to do something like this:
root /php-fpm-root/nextcloud/
fastcgi / nextcloud:9000 php {
root /var/www/html/
That way, Caddy serves the static files from /php-fpm-root/nextcloud/, but for fastcgi in the nextcloud container, the files are located at /var/www/html/. I see that thereâs an expanded way of doing php_fastcgi, and this does seem to work, but that literally doubles the size of the Caddyfile. I was wondering if it is possible to do some sort of a root directive in the php_fastcgi directive, as you could in V1.
{"level":"info","ts":1589669822.9492817,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: parsing caddyfile tokens for 'php_fastcgi': /etc/caddy/Caddyfile:38 - Error during parsing: transport already specified
{"level":"info","ts":1589670658.2529993,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: parsing caddyfile tokens for 'php_fastcgi': /etc/caddy/Caddyfile:38 - Error during parsing: unrecognized subdirective root
I tried the above Caddyfile (which doesnât work, first error above), as well as:
root /var/www/html/
(whcih also doesnât work, second error above). I also tried the expanded form, which I think works but isnât going to be fantastic once I add all my other php sites. I also tried just mounting the nextcloud html directory right into /var/www/html/ in Caddy, and that works too, however if any other container comes around that also uses /var/www/html/, I wonât be able to use it.
V1 was like this: Nextcloud via Docker and Caddy ¡ GitHub
7. Final Thoughts
This wasnât so much a call for help as it was a question. Iâd like to be able to override the root path for php_fastcgi, without having to rewrite the whole thing in expanded form. Is that possible?
