V2: Logging to file, permissions issues
v2.0.0
installed with sudo apt install caddy
Ubuntu 18.04.4 LTS bionic
sudo systemctl enable caddy
sudo systemctl start caddy
with Caddyfile at /etc/caddy/Caddyfile
plantsdb.xyz {
    output file plantsdb.log {
      roll_size 5
      roll_age 5000
      roll_keep 1000
  tls myrmecocystus@gmail.com
  reverse_proxy localhost:8888
ftdoi.org {
    output file pubpatterns.log {
      roll_size 5
      roll_age 5000
      roll_keep 1000
  try_files .html /
  reverse_proxy localhost:8876
I don’t understand where logs are being recorded. I think I have logs set up with the log directive to go to a file for each of my domains. With Caddy v1 access logs were written to the file. I’m not seeing logs recorded to these files with Caddy v2.
running sudo systemctl status caddy I see
write error: can't rename log file: rename plantsdb.log plantsdb-2020-05-18T17-22-08.158.log: permission denied
write error: can't rename log file: rename pubpatterns.log pubpatterns-2020-05-18T17-22-24.066.log: permission denied
If i try deleting the existing log files (from previous Caddy v1) i get
write error: can't open new logfile: open plantsdb.log: permission denied
I tried changing permissions of the log files (e.g., chmod 755 pubpatterns.log) but that doesn’t seem to help.
possibly related posts:
I don’t think the caddy user has permission to write to that location. I think if you specify the log file path as /var/log/caddy/plantsdb.log, it might work.
FYI, I don’t think this will do what you want. This will check if there’s a file on disk (relative to the directory in which Caddy is running) named .html (there won’t be), otherwise it will check for a file / on disk (there will pass, because the current directory exists).
try_files isn’t very useful along with reverse_proxy because Caddy doesn’t know what files the proxy is serving.
I think you’re probably looking for something closer to this, but I’m just hazarding a guess:
@notHtml {
    not path *.html
rewrite @notHtml {path}.html
Thanks @francislavoie
Created /var/log/caddy/ directory, and tried that file path in the Caddyfile. That results in the same error, permission denied.
Is there docs on where caddy user has permission to write?
Thanks for the try_files tips. I was confused about that so glad to have some help.
When installing with the apt repo, currently it’s only directories where the caddy user has permissions. I think by default it’s only /var/lib/caddy and /tmp, maybe a few more places. See here, this is essentially what the apt repo does:
Along with the next releases, we’ll add the caddy user to the www-data group so that should allow it to access more relevant locations on disk.
For now, I think you could create the /var/log/caddy directory and chown it to allow the caddy user to write there.
Thanks very much. chown the /var/log/caddy dir fixed it.
