caddy:2-alpine
Running it from a docker-compose
file.
docker-compose
Here ist my current docker-compose
version: "3.7"
proxy:
external: true
internal:
external: false
driver: bridge
image: caddy:2-alpine
- ./config/Caddyfile:/etc/caddy/Caddyfile
- /config/caddy/data:/data
- /config/caddy/config:/config
- proxy
- internal
portainer:
image: portainer/portainer-ce:latest
container_name: portainer
command: --http-enabled
security_opt:
- no-new-privileges:true
- proxy
- ./data:/data
- "127.0.0.1:9000:9000"
- url=https://portainer.example.com
Ubuntu 20.04 LTS running on a KVM VPS
Docker Version: 20.10.15
Docker-Compose Version: 2.5.0
docker-compose up
email info@example.com
# Optional staging lets encrypt for testing. Comment out for production.
portainer.example.com {
reverse_proxy portainer:9000
@blocked not remote_ip MY_VPS_IP
respond @blocked "Access Denied" 403
# enable HSTS
#Strict-Transport-Security max-age=31536000;
# clickjacking protection
X-Frame-Options DENY
# Content-Security-Policy: default-src 'self'
wireguard.example.com {
reverse_proxy wg-easy:51821
# enable HSTS
Might be relevant, my docker-compose
for Wireguard:
version: "3.8"
wg-easy:
# ⚠️ Required:
# Change this to your host's public address
- WG_HOST=wireguard.example.com
# Optional:
- PASSWORD=PASSWORD
- WG_PORT=51820
# - WG_DEFAULT_ADDRESS=10.8.0.x
- WG_DEFAULT_DNS=1.1.1.1
# - WG_MTU=1420
# - WG_ALLOWED_IPS=x.x.x.x
- url=https://wireguard.example.com
image: weejewel/wg-easy
container_name: wg-easy
- .:/etc/wireguard
- "127.0.0.1:51820:51820/udp"
- "127.0.0.1:51821:51821/tcp"
cap_add:
- NET_ADMIN
- SYS_MODULE
sysctls:
- net.ipv4.ip_forward=1
- net.ipv4.conf.all.src_valid_mark=1
- proxy
proxy:
external: true
internal:
external: false
driver: bridge
I’m trying to get whitelist working to have access to various apps running on the same Server while connected to Wireguard (Portainer, Grafana, Prometheus, etc. - In this example I’m only using Portainer as a starting point).
I’m using UFW with this workaround for Docker and allowed 127.0.0.1
on Port 9000
Accessing Portainer without connected to Wireguard VPN works without a problem.
But as soon as I enable the whitelisting I can’t access it when connected to Wireguard. (Getting the defined message in the Caddyfile
- “Access Denied”).
No errors when connecting to Portainer while connected to Wireguard.
I’ve tried to whitelist the Server IP (which I got from here) aswell as the all IPs I got from executing ip a
on the server and the sandbox IP I got from Wireguard.
Disabling UFW doesn’t work either.
The Docker network is present (docker network create proxy
Checked a similar topic on your forums here: V2: basicauth + ip-based whitelisting - Help - Caddy Community
Read the docs which are linked in that topic.
I’m not sure if this Docker or Caddy related, since I learned about Docker like 3 weeks ago and just switched from Traefik to Caddy.
So it might be a networking issues on my end here.
Thank you very much for you help!
