V2. HTTP to HTTPS redirects fail for on_demand SSL certs
v2.0.0-beta10
Please provide all of the relevant information and DO NOT REDACT anything except passwords/keys. Thank you!
Created from Digital Ocean Marketplace app, which uses Ubuntu
caddy start
curl -X POST "http://localhost:2019/load" \
        -H "Content-Type: application/json" \
        -d @caddy.json
c. My complete caddy.json file:
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [":443"],
          "routes": [
              "handle": [
                  "handler": "reverse_proxy",
                  "upstreams": [
                      "dial": "{IPADDRESS}:1111"
              "match": [
                  "host": ["api.domain.com"]
              "handle": [
                  "upstreams": [
                      "dial": "{IPADDRESS}:5555"
          "automatic_https": {
            "disable_redirects": false
          "tls_connection_policies": [{}],
          "logs": {}
    "tls": {
      "automation": {
        "policies": [
            "management": {
              "module": "acme",
              "ca": "https://acme-v02.api.letsencrypt.org/directory",
              "on_demand": true
        "on_demand": {
          "rate_limit": {
            "interval": "10m",
            "burst": 2
HTTP to HTTPS redirect does not work for domains which generate their SSL certificates on_demand. HTTP to HTTPS redirect only works for api.domain.com.
A curl command to http://domainpointedatserver.com returns nothing. A curl command to https://domainpointedatserver.com returns the correct site.
Everything I could think of including manually setting disable_redirects to false, and listening on port 80.
Thanks for the report, and for trying Caddy 2 while it’s still in beta. Will be looking into this!
@podpage I think I’ve fixed this in https://github.com/caddyserver/caddy/commit/994b9033e96da270dca48ab01377431028c06b52. Are you able to build from source on the v2 branch and let me know how it works for you?
Hi Matt,
I am running into the same issue. I pulled down your latest commit (beta 11) and it doesn’t seem to fix it. I am getting a nil pointer error in the logs when I try to access via http but not https.
 /home/user/Projects/caddy/modules/caddyhttp/server.go:192 +0x740
Here is my Caddyfile:
blog.example.io {
	root * /var/www/example.io
The latest commit will be in beta 13; beta 11 doesn’t have the fix. You’ll have to build from source on the v2 branch to get it right now.
