V2: howto simple redir in Caddyfile?
v2.0.0-beta9 h1:oILdAOfunJ4ijBN9kOWjFIeH8EufBX/N1pC9HbnwjzU=
Ubuntu 19.10 eoan (GNU/Linux 5.3.0-22-generic x86_64)
systemd 242 (242)
+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid
/usr/local/bin/caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
Here’s my caddy.service file for systemd:
Description=Caddy v2 web server
Documentation=https://github.com/caddyserver/caddy/wiki/v2:-Documentation
After=network-online.target
User=www-data
Group=www-data
; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
ExecStart=/usr/local/bin/caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile --adapter caddyfile
; Use graceful shutdown with a reasonable timeout
ExecStop=/usr/local/bin/caddy stop
KillMode=mixed
KillSignal=SIGQUIT
; Unmodified caddy is not expected to use more than that.
LimitNPROC=4096
; They further restrict privileges that can be gained by caddy. Uncomment if you like.
NoNewPrivileges=true
d. My complete Caddyfile:
	storage file_system {
		root	/etc/caddy/whatever
	experimental_http3
sunrisemovement.dev, www.sunrisemovement.dev
root * /srv/sunrisemovement.dev/public/
try_files {path}.html {path}
encode gzip zstd brotli
I just don’t know how to do a simple redirect from https://sunrisemovement.dev to https://www.sunrisemovement.dev in the V2 Caddyfile. Any functioning redir examples would help me out a lot. I tried a bunch of ideas but I’m just flailing in the dark, Caddy has refused to load all of my attempted Caddyfiles (I’m sure they were all terribly wrong). The one pasted above is one that works, but it obviously doesn’t do the redirect I want. A v1 Caddyfile would have written it like this:
redir 301 {
    if {host} starts_with sunrisemovement.dev
    / https://www.sunrisemovement.dev{uri}
Help?
Thanks for trying v2 while it’s still in beta!
This is the syntax:
redir [<matcher>] to [<code>|permanent|temporary]
Have you tried:
redir https://www.sunrisemovement.dev
Ohhhh now I understand the syntax slightly better! That did indeed work, with the following Caddyfile:
	experimental_http3
# test page
www.sunrisemovement.dev {
Thank you!
That’s a good-looking Caddyfile right there! Have fun.
