I use Caddy V1 to host sites that are automatically pulled via the git middleware in Caddy V1.
Is there a git plugin equivalent for Caddy V2?
Yes there is!
It only supports JSON config for now, due to some limitations in the Caddyfile adapter currently, but Caddyfile support should come eventually.
